Gta4 problem
571 Views 15 Replies 10 Participants Last post by  brkbeatjunkie
hi,
i just have installed gta4 on a clean pc just formated my pc and im having some problems playing the game: lagg,... and the games auto settings is auto. at high settings + i have played the game before with no issues.
i thought it could be with my grafxcard but its kinda impossible cause im running on a Gforce Nvidia gtx 285 1gddr.
i hope u guys can help me so i can play gta 4 again
cheerz
1 - 16 of 16 Posts
Weird, maybe try taking the setting off of auto
Formatted your pc? Maybe you need to install some updated drivers?
i have the latest nvidia driver installed i installed everything before i installed my games (duh) :d
what speed are you running your Q6600 at ??? also i dont think 2GB of ram is enough for GTA4
im running on a 2.40ghz intel quadcore E6600 i got 3 gig ram
Your lag is probs because a stock Q6600 (2.4GHz) is not fast enough to run GTA4 on high settings, it will also be bottlenecking your GTX285 it would bottleneck an 8800GT at that speed
k i will see what i can do about that but im wondering then why its only with gta4 and not with Call of Duty modren warfare 2 play everything open on that game aswell.
Because GTA 4 is a badly coded and optimized title whilst Modern warfare 2 is optimized and a lot less intensive title to begin with
GTA4 takes more resources to run than MF2, ALOT MORE! If you look at the sys requirements for MF2, you only need a P4, 256Mb GPU, and DX9, LMAO! I mean the game is BA, but it really isn't a resource load like GTA4 is!
hi,
cheerz
Just installed on a clean install of windows? HHMMM sounds like you need to download the updates for the game, did you update?
yes i updated to the last version of Gta4
Did you install the necessary and correct graphics drivers? If all else fails, looks like you might have to do a clean install of GTA IV again...
Like many others have said, GTA IV was just a horrible port. It's a very fun game, but coded by seizing monkeys with keyboards.
If the game was playable before the format, in which I think you said it was on your machine, then try older display drivers if you have not tried already...Try the ones you were using before the clean install
hi,
cheerz
I have noticed that GTA4 eats CPU's for little snacks. I believe your graphics card is more than enough to handle the rendering side, but let me tell you when I went from the Amd Athlon 7750(i think thats it) dual core at 3Ghz to my phenom quad 955 at 3.6ghz, my fps literally doubled. I believe this is due to the vast amounts of AI scripting (cars and people etc). perhaps try benchmarking with different CPU speeds to see if that is the issue. best of luck!
1 - 16 of 16 Posts
