1 - 20 of 20 Posts
Just installed the game and all was fine until it came to the part where you start to drive off roman's car, the screen was blank just audio, the map and cash data were showing and when i turned the cam, the map got blurry. So i ran the bench and came out and it worked this time until i started driving and it just got real blurry so i quit the game an restarted there was no starting cutscene this time and after the 1st cutscene there still was nothing but the blank scene with the map and cash data showing.
Tried restarting my pc / running the game with gpu stock, doubt its my oc cuz i play everything else 100% and ccc setting are stock
doubt a re-install can help this.
The game might load up sometimes, and as i exit the door of the apartment, goes blurry like a negative effect.
Any idea what can fix this?
turn off vsync
Originally Posted by Rizzle
there is no vsync setting in game...
yes there is.
did you download the patch if not do so it fixes some or most of the bugs in the game
http://games.softpedia.com/get/Patch...IV-Patch.shtml
my gta 4 does not like any OC on my video card try at stock settings and see if its OC and download ati 10.3 if you dont have it installed yet
Originally Posted by Rizzle View Post
@ cerebus i see none and ive been playing this game on pc a long while now
then you fail.
LOL EPIC ending. I got tired of this game. I'll just wait for the GTA V if THEY do make it and hopefully they can improve LOTS of things. Done modding GTA IV.
The original release of GTAIV was missing a ton of settings and I'm pretty sure vsync was one of them. If your graphics screen doesn't look like Cerberus's it means you need to update and would probably explain why you're having numerous issues. When GTAIV was first released it was insanely buggy and was missing a ton of graphic settings. 1.0.5.0 is the latest patch.
Discussion Starter · #13 ·
cool ..knew it had to be a patch prob, will try later on ..this is the 1st time ive ever had a prob with gta4
So wait you have never patched GTA IV after installing it?
Originally Posted by Cerberus
then you fail.
you installed the new update, that is why you have those settings like shadow and water quality
but I can't remember if v 1.0 had vsync or it was added later
GTA IV has issues. like being a bad and horribly coded console port.
Make sure you have all the patches, drivers and whatnot. If you run out if ideas, smash the game discs and box in a fit of rage and be done with the game once and for all.
Seriously though, get those patches.
1 - 20 of 20 Posts
