GTS 250 Help
727 Views 12 Replies 8 Participants Last post by  redman22m2003
I as check to get people opnion. I just built a Quad Computer and looking to SLI two card. I will be using these card for mainly Gaming and watching Bluray movies. My computer soecs are:
EVGA 750I Motherboard
Intel quad 2.33 GHZ
6 GB of dual channel DDR2 pc6400
1TB Western digital 7200 RPM 32 MB Cache
Window Vista Ulimate x64
ASUS Blu ray rom
Cool Master V-8 CPU cooler
650 WATT Consair PSU
I was thinking about SLI two XFX GTS 250 cards
Link:
http://www.newegg.com/Product/Produc...82E16814150357
Any help would be great
1 - 13 of 13 Posts
EVGA 512-P3-N977-TR GeForce 9800 GT Superclocked Edition 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
you are better getting these
http://www.newegg.com/Product/Produc...82E16814130450
$134.99
($114.99 after $20.00 Mail-In Rebate)
250 is nothing but a 9800gt
plus they are single slot coolers on this card and not double like the 250
will my current PSU enough for either card?
Originally Posted by Setzer
Save just a little tad of money and get 2 of these http://www.newegg.com/Product/Produc...82E16814130468
$134.99
Both of your recommendations include cards that only support a 2 year warranty.... i find it disgusting that evga is not selling a GTS250 with their normal lifetime warranty.
@OP Go with those XFX cards, they atleast include a double lifetime warranty, too bad the cooler on them is ugly as hell.
Correction, the upcoming GTS 240's are just 9800 GT's the GTS 250's are 9800 GTX+'s
Welcome to Overclock.net! Fill out your System Specs.
Before you think about going SLI, I would ask what size/rez monitor you have. I'm assuming because you said blu-ray you've got a 24/1920x, but if not forget SLI. I would suggest XFX 260 GTX 216.
the xfx 260 SLI, i thought i need a bigger PSU than 650 thats why iwas thinking abotu the xfx 250
I think he was suggesting a single gtx 260. Less noise, less power, similar performance and less conplications depending on who you ask.
A 650W PSU should be fine for GTX 260 216 SLI, because together, the two cards use about 400W, leaving 250W for the rest of the system.
i have a gts250 heat wont be a prob in sli, overclocked mine runs at 40C constantly with the fan at minimum dont know if this is because of the heatpipes or what but i highley recomend one or two
okay, i will by two of these:
http://www.newegg.com/Product/Produc...82E16814150329
DUKE EDIT:
Please read the "For Sale Rules"
You may NOT post any items for sale in any way shape or form at overclock.net untill you earn the appropriate REP level.
1 - 13 of 13 Posts
