So I have an old 9800 GX2 that I tried to revive and was unable to, now I have a GTS 450 and want to use the cooling from the GX2 on the GTS 450. Average temps with slight adjustment on overclock is *72 under load, the list of what I have for power and power consuption.
CMStacker 830 case with 6 120mm fans
1 HDD
GTS 450
Phenom X3 8550
Coolmax ZX-500 for power
1 DVD write read burner
So my question is, will the gpu cooler match up with GTS 450 from which I understand offset holes pretty much stayed the same. And problems with my power supply and the added cooler from the GX2 be an issue? Anything I am missing on doing this?
1 HDD
GTS 450
Phenom X3 8550
