1 - 2 of 2 Posts
i'm planning to buy palit gts 450 512mb ram and couple it with my old 9600 gt as a dedicated physx. is this setup ok? or i'm far better just gts 450 without physx? btw, gaming resolution is 1360x768
I don't think that they make a 512mb I think the only thing they make gts450s in are 1gb - that being said, having a dedicated card to take the work load off of physx if you decide to use it is always helpful. - if you can spare a couple extra $$ I think that the gtx460 768mb version would do you much better than the gt450 and is fairly close in price - check with newegg.com open box, you can usually score something pretty good
1 - 2 of 2 Posts
