1 - 3 of 3 Posts
just trying to see what people think of using a 350w 80 plus gold psu
with a gtx 1070
build would be msi nightblade( included 350w 80plus gold)
DDR3L ram
i7 4790T (45w)
Senior OCN Member
Really depends on which 350 watt PSU you are talking about.
But yes if you are not going to overclock anything you can run a whole system with a GTX 1070 off a good 350 watt PSU
I would say that technically it should barely be enough, your probably going to be in the 280-320watt range at the wall. Personally a bit close for comfort but if its a good psu it should take it for gaming sessions, I personally just dont like being that close to the limit on a psu that msi doesnt seem to advertise the make/model.
1 - 3 of 3 Posts
