GTX 260 with accelero S1 rev 2?
3128 Views 3 Replies 3 Participants Last post by  hawktulu
Hi guys, I wanted to ask if i could fit accelero S1 rev 2 with GTX 260?
simple question
Im getting 4850 matrix, I had 8800gt with accelero S1 which is amazing cooler - cooling it down by 35degrees.. I want to use accerlero S1 rev on gtx 260, but I dont know if it can be fit on 260 or I need to buy extreme 280gtx?
thanks
1 - 4 of 4 Posts
No, the accelero S1 V2 will not fit the GTX 260... the mounting holes do not fit
You'll need to buy accelero Xtreme GTX 280 version, or the Thermalright HR-03 GTX
Mounting holes do not match up. So, unless you intend to craft your own custom mouting hardware, you are out of luck...
Untill you can buy the Accelero Xtreme GTX 280 anyway.
so with default mounting holes I cant...but if I made new one it could be fit on...
thanks guys
1 - 4 of 4 Posts
