Hello Everyone,
I had posted a thread whereby I had requested advice on components as I was going to upgrade my computer. I am thankful to all of you for your advice and support.
I have a new pc now with the following config -
-C2D 3GHZ
-4 GB RAM
-Leadtek GTX 275
- (See Signature)
Now everything is working fine, OS windows xp installed and several softwares installed. So far so good.
BUT my GPU GTX 275 is overheating if I run a game. I have 2 fans on my cabinet (left side) which blows air in and my SMPS blows air out.
As soon as I run game NFS Undercover, my GPU starts beeping and if I check temperature then it shows 80 celcius. And this happens as soon as I run the game and not if the game has been running for a while. Moreover I think my GPU fan speed is locked at 40%. Why isnt the card adjusting fan speed automatically.?
My CPU is okay and shows temp around fifties (celcius). Cabinet has decent room so its not really crowded.
What should I do ? GTX is a big card and i dunno installing another fan or so with thermal paste may not be an easy task.
Man I got a new machine and now I can;t use it for gaming.
Please help me out guys.
Thanks a lot,
Cheers,
GR
-C2D 3GHZ
-4 GB RAM
-Leadtek GTX 275
- (See Signature)
Thanks a lot,
Cheers,
GR
