It seems that many have to connect the monitor to both sides of the sandwich to get 2 cores working. Anyway, first of all, I've never tried this on anything other than the 182.08 WHQL driver. I do have dual monitors but both are plugged to the DVI ports, so one side of the sandwich (the HDMI side) isn't connected to anything.
After I disabled multi-GPU mode, I went to display properties and saw three monitors, and of course I know that monitor 3 isn't connected to anything. However, I was able to enable it and extend my desktop to this non-existent monitor. Then I hit OK. The whole trick is that you only need to get it enabled but not necessarily connected to any physical monitor or even a dummy plug. Now I'm getting 15k PPD total with a 511pt WU and a 353pt WU.
I've attached an image below. Can some other 295 users out there test this out and see if it works? (182.08 WHQL driver + empty HDMI port)
EDIT: Method confirmed working -
http://www.overclock.net/5729120-post15.html
Here are the instructions:
1. Enable multi-GPU mode.
2. Disable multi-GPU mode.
3. Right-click on desktop and navigate to display properties.
4. You should now be able enable monitor #3.
5. Run GPU2 clients! |
