What graphics card manufacture do you prefer?
  • Asus
    Votes: 4 9.3%
  • BFG
    Votes: 6 14.0%
  • eVGA
    Votes: 25 58.1%
  • Gigabyte
    Votes: 1 2.3%
  • MSI
    Votes: 1 2.3%
  • PNY
    Votes: 0 0.0%
  • XFX
    Votes: 5 11.6%
  • Zotac
    Votes: 1 2.3%
  • I buy whatever is cheapeast
    Votes: 0 0.0%
1 - 15 of 15 Posts
I thought I would start a thread dedicated to overclocking & overvolting the GTX 295. I figure this will be a good way for people to share there tests, temperatures and overvolt settings using the GTX Voltage Tuner. It will also give a general idea as to what manufactures clock & perform the best. In the end I would like to compile a spreadsheet.
Note one:
If you are an extreme owner & have a Quad configuration please only test one GTX 295 at a time.
Note two:
Photos, please use the standard format for this forum as I do not know it.
Note three: If you submit more than once just keep editing your post with
your new results leaving the prior result.
Please use the following template below.
Examples:
Memory:4 GB, OCZ Flex2 PC 9200 @ 1131Mhz, 5-5-5-15
CPU: E8500 @ 471*8.5
Cooling- Stock, H2O -EK water block etc.
Owner:
Mainboard:
Memory: @
CPU: @
PSU:
Card Model: GTX 295
Card Manufacture:
Cooling:
Temperature:
Bios Rev: Stock
Millivolts:
GPU Clock:
Shader Clock:
Shader linked:
Memory clock:
Physx enabled on GPU:
Secondary GPU for Physx:
Did your capacitors squeal? Yes, No or I did not care to listen
Driver Version:
Operating System:
Vantage Score:
-Use the performance setting with registered Vantage copies
-Include either a validation link or screen capture for Vantage along with a GPUZ & CPUZ screen capture.
-The driver version does not have to be FM approved.
-(Please do not disable PPU if you are using a registered version)
Discussion Starter · #2 ·
Owner: broke pixel
Mainboard: DFI UT X48 T2R
Memory: 4 GB, OCZ Flex2 PC 9200 @ 1180Mhz, 5-5-5-15
CPU: E8500 @ 492*8.5
PSU: ePower Tiger 1200 watts
Card Model: GTX 295
Card Manufacture: BFG
Cooling: H2O, Danger Den water block
Temperature: GPU1 idle 38c GPU2 idle 36c load 49c during Vantage
Bios Rev: Stock
Millivolts: 1188 mV
GPU Clock: 780 Mhz
Shader Clock: 1681 MHz
Shader linked: Yes
Memory clock: 1200 Mhz (2400 MHz)
Physx enabled on GPU: Yes
Secondary GPU for Physx: No
Did your capacitors squeal? Yes not as bad as my MSI 8800 Ultra
Driver Version: 185.20
Operating System: Vista 64bit SP2
Vantage Score: P25861
http://service.futuremark.com/compare?3dmv=866199
Ah! The wait, what manufacture did you go with?
· Premium Member
Originally Posted by gibsonnova74 View Post
Do you need a SLI board to run the GTX 295 in SLI? The cards come with chips that allow you to run SLI without having a SLI board, right?
No you don't need an SLI board, unless you want to run Quad x2 295's. I have a DFI X48 board made for Crossfire and run a single 295.
The X58 chipset's support Hybrid SLI so you can run either Crossfire or Nvidia SLI.
Discussion Starter · #11 ·
Hello, anyone ;(
Owner:Rymn
Mainboard: EVGA 680i
Memory:8gb @ 950mhz
CPU:q6700 @ 3500mhz
PSU:850 modular
Card Model: GTX 295
Card Manufacture: XFX
Cooling: Stock
Temperature:Average?
Bios Rev: Stock
Millivolts:
GPU Clock:stock xfxoc
Shader Clock:stock xfxoc
Shader linked:stock xfxoc
Memory clock:stock xfxoc
n 8800gt
Secondary GPU for Physx:8800gt
Upgraded from 260
Discussion Starter · #14 ·
Max i have braved is 800Mhz core, shaders [email protected] 1200mV
I'm sure it will go much higher.
Thanks for the post and look forward to some results.
1 - 15 of 15 Posts
