ThisOriginally Posted by tehmaggot;13088623
Don't do it. The 9800GT won't be fast enough and it'll essentially slow down your two 470s. It won't be able to do PhysX at the same rate at which the 470s will render frames, so the framerate will suffer.
Originally Posted by Mr.Cigar ![]() To be honest, even Mafia II, a single GTX470 is more than enough to handle it with everything pushed max, include Physx. The answer is no. |
Originally Posted by Defoler ![]() I completely disagree. A 470 will be very hard pressed with everything maxed out and physx. Mafia 2 isn't very demanding, but everything maxed with physx? Not a chance. I point you to here. You can see from his test, with everything on high and with no physx, a single 470 has an average of about 45 FPS. Add physx to that, and you are pretty much expecting a choppy 30-35FPS, as physx is extremely demanding on this game. |
