1 - 6 of 6 Posts
I recently purchased a Gigabyte 470 Super Overclock to SLI along with MSI 470 that came with my rig. Anyways just had a couple of questions. My power supply is 750W and I was told to SLI two 470 cards would be fine but would need to upgrade my power supply if I were to add a 3rd (which I find unnecessary). My question(s) are:
Whats the best program to overclock?
What would be a good overclock setting on each card so I dont go over the 750 power supply?
Thanks for the help
what kind of power supply are we talking? because your overclock may push it close.. and btw MSI Afterburner is the way to go
Discussion Starter #4
well i purchased a acer predator g7750 so its the 750w that came with it but i know i can add a second just wanted to know how far i can OC each
liquid cooling should also help the heat
I don't know what power supply comes with an acer predator but if it is a generic one I would not trust it too much, Maybe keep an overclock of 700 on the core? (Might need to bump up the voltage a bit ... possibly up to 1000)(1v)
If you said you had a Corsaie 750w or something i would say to you go ahead and overclock as much as you can !
1 - 6 of 6 Posts
