1 - 20 of 22 Posts
Discussion Starter · #6 ·
Originally Posted by Riou;13051482
6950 and 6970 can overclock too. They will beat the 560 Ti SOC on average when overclocked as well.
MHM yes but the gigabyte has a 100% of running at 1ghz+ and they scale better in SLI. you cant overclock well when using crossfire on these new cards....that is what I have been told
Originally Posted by Aniket;13051557
hd6970 crossfire is the clear winner,
its almost equivalent to gtx580sli,
I wouldnt recommend u to unlock hd6950 crossfire.
Only crazy nvidia fanboys will ask u to go with gtx560ti sli,
hd6970 cf kills gtx560ti sli,moreover amd 6series gpu scales extremely well.
Hope this helps u.
Hmh ok well I havent had many cards a 4350,4890,5870 crossfire, and then ones im buying now
My asus 6950 2gb reference unlocks great! running at 840/1325 right now since i dont want to push it yet. took me 5 mins to unlock it! at 60c under load @50% fan profile. Its not loud at all. Based on all the reviews and benchmarks I seen, I picked the 6950 2gb since it can unlock. Under crossfire, it scales extremely well, most of the benchmarks I've seen it matchs or beats the 570gtx SLI
Discussion Starter · #12 ·
Originally Posted by Tom1121
560's scale like crazy when overclocking, but with 3 monitors go 6970. Hopefully Kepler will have a minimum of 3gb of VRAM
I dont game with 3 that often only on dirt 2 and fallout sometimes so using one monitor what is the best choice?
forget about those old days dude,
amd 6series gpu's scales extremely well....like sli does
who told u they dont oc well when they are crossfired?
They oc very nicely,many OCN members have hit 1ghz with 2x/3x hd6970 crossfire
Discussion Starter · #14 ·
Well Im running my Diamond 4890 XOC until I get new cards
2GB 6950s use a little less power (although produce more heat) than a couple of 560 Tis, and IIRC it can unlock shaders (someone correct me if I'm wrong on this - I'm pretty sure you can).
6950s seem to scale a bit better at higher resolutions than a couple of 560 Tis, so if you can find some decently priced 6950s you should try and get a couple of them.
EDIT
CRAP! I got this confused for another thread I think started also by you, asking for GTX 560 Ti 2GB vs GTX 560 Ti 448.
Sorry!! I'll take out the part about the 448 core Ti.
But my answer remains, 6950 2GB crossfire.
1 - 20 of 22 Posts
