Single 680 for sure. SLI 570 1.28GB will be VRAM limited in some games at 1080P, so even if the average FPS is higher than a single 680, the minimum FPS may drop much lower.
I have two MSI Twin Frozr iii 570 cards and I'm definitely scoring better than a 680 in 3DMark11, however make sure you get the 2560MB version of the card if you do decide to go down that route. The standard 1280Mb version will cause you problems at 1080p and above.
no he said the second generation of 600 series i.e a 685 or 690.Originally Posted by mx1701
I also read here that the second wave of 680 will be better:
http://www.teamplayergaming.com/pc-hardware-technology/102107-gtx-570-sli-vs-gtx-680-a.html
No clue what that means...
Did you ever tried a multi gpu config? Make sure u have a 120hz monitor to avoid any kind of stuttering/tearing issue if running multi gpu or go for a single 680 btw in any case i suggest a 120hz monitor.
September? What about Maxwell? And the 690 should be out sooner! I think it is fake.Originally Posted by mx1701
What about this??
http://videocardz.com/31650/geforce-gtx-685-gk110-features-4gb-512bit-memory
