1 - 6 of 6 Posts
My question is I have 2 gtx 580 1.5 gb
And I just bought the 3rd one
The 3rd one is 3 gb which I realized when I got home and there is no way of returning it
So I was thinking if I use the 3rd one (3gb) as primary card and when I disable sli do I get a use of 3 gb ram or. I know when I enable sli it's uses only 1.5 gb of ram because of my other card.
Does it still uses is 1.5 gb
Help me guys here need some answers.
Thanks
Washed Up Old Gamer
using the primary card only you should have the full 3gb of vram. I'd trade it off for a nice 1.5gb card though and see if you can pick up a few bucks.
Yup you get all 3GB when SLI is disabled and set as the primary card.
Discussion Starter #5
Thanks alot guys do when I disable the sli I will get full advantage of 3 gb VRAM and my mobo is a EVGA 4 way classified should I put the 3 gb all the way to the first slot I mean stak them in a row or should I skip a slot
Any way my gpus are hydro copper 2 water cooled EVGA
Yes 3GB model in top slot
1 - 6 of 6 Posts
