1 - 10 of 10 Posts
So I've got the upgrade itch, and I'd like to either upgrade my GPU or CPU. Right now I have a 2500k @ 4.6 GHz and a GTX 460 @ 820 MHz. Which would be a better upgrade as far as folding is concerned? Getting a used GTX 570/580 or getting a 3770k? I'm leaning towards a GPU upgrade since my 460 has been repaired by baking before and likes to crash from time-to-time, and of course it's the better upgrade for gaming, but if I were to upgrade my CPU I'd have an average 2500k to sell or use in another build.
Another question, can you overclock Ivy Bridge on a P67 motherboard? I thought I read only Z77 could overclock Ivy but confirmation would be nice.
Get the GTX 580.
Originally Posted by NITRO1250 View Post
Get the GTX 580.
This!
Or a GTX 670.
Also, it depends on the board, some boards require BIOS updates that will allow you to do some mild overclocking, I don't know how far you'll be able to push it, but you most certainly can overclock.
Edit: There will be some more BIOS updates in the next few months to address overclocking issues across most boards.
Edit 2: Keep forgetting things haha, UEFI BIOS's will be fine. I think it's primarily the Gigabyte boards, I'd do some more research but, I'm busy at the moment! Sorry
Would you rather fold or game? 580 for folding, 670 for gaming, or... if you're not bothered how well it folds, a 670 isn't exactly terrible at it. Google around for some benches!
Discussion Starter #7
I probably care a little more about folding at this point. My 460 is plenty powerful for the games I do play so I wouldn't be upgrading solely to improve gaming, it just has issues since it's been oven-bake-repaired before. I've also seen GTX 580's sell used for fairly cheap because of the new 600 series so it seems like a good time to upgrade.
You can overclock an ivy bridge on P67, yes. But it's only a tiny insignificant processor upgrade. Not worth your time unless you do heavily multi-threaded work. A GPU upgrade would be much more noticeable for gaming. Not sure 580 is the way to go though. Check prices vs 670 or 7870/7950.
a second gtx 480! and save up the rest for GF 110
AHh sorry I misread everything 0.o........
well take a-look around and see if you can find a gtx 580 around thatd probably be your best upgrade! or maybe a second gtx 460 to hold you till next gen??
1 - 10 of 10 Posts
