Hi everyone, decided to finally replace the stock cooler on my 680 due to it developing a faint grinding noise audible at all fan levels (hard to explain, hope that makes some sense). So I decided on the Mono Plus, I made this choice with confidence since the announced compatibility with the 670.
Pictures!:
With a keen eye you might notice there's a fairly prominent bend in the PCB even with the ram/vrm plate screwed on, I forgot to take a snap of it, but this becomes more prominent when that plate is taken off, rather odd.
The usual.
A screw goes directly through this to the ram/vrm plate so I easily remedied it with a large screw and nut to fit (which once again I forgot to take a direct picture of, but further down you'll notice it)
Not being a fan of the curing times of AC's new adhesive I decided to use some thermal tape. This is also the stage I planned heatsink layout.
All stuck on and ready to receive the Mono Plus
Voilà, Installed (In the top pic you can notice the nut of the screw I used for that hole before)
Thus it finds itself inside my rig.
Max temperature I've seen so far is 54°c in Saints Row the Third. Idles at around 26°c
I would run furmark etc for everyone, but I don't believe the heatsinks on the VRM are doing too well, my card used to auto-overclock it self to about 1084mhz (never stayed at that due to the stock cooler getting over 70°c) but now it hardly goes past 1058, and the vrm heatsinks themselves are very hot to touch (sadly non of this changes even if I put a 120mm fan going full blast over them).
If anyone has any questions/suggestions/requests, feel free to reply below and I'll see what I can do.
Pictures!:
The usual.
