1 - 4 of 4 Posts
Any one know if there is any GTX 690 water blocks that support a back plate,
Was looking to get some from XSPC or Koolance, but don't know if they can support a back plate. I think EK has a custom back plate for its block, but I find it rather plain looking.
You could also go the route I'm going. I bought the Razor block and I'm having Dwood over at the artisans forums make me a custom backplate for 30 bucks. Well worth it cause you get to have it done to your specs.
1 - 4 of 4 Posts
