How can i overclock when precision X doesnt allow more than 6% more power? and the video driver crash when i even do a 50MHZ clock?
Either edit your own using GPUZ and NiBiToR (if you choose to pursue this then I can explain more in depth) or just search up a pre-made BIOS online that has already unlocked the voltage. Then you'll need nvflash to flash your new BIOS onto your card, as well as a tool like the HPUSBBoot tool that lets you boot from a USB drive. You can install Windows 98 DOS to the drive so that you can flash it. It is way less complicated than it seems.
Sort of, you extract your previous BIOS with GPUZ and then edit that in NiBiToR as a seperate BIOS. Then you flash your new one.
