1 - 1 of 1 Posts
Hello,
So I am new to Nvidia. I just got an Asus Gtx 950 Strix. I overclocked it a little bit yesterday and I got good numbers. Currently it is running at 1503/8200mhz. But I feel like at this point it just needs a tiny bit voltage adjustment. Apparently these cards are limited to 1.212. So I don't want to use any other modded bios or change any other bios settings (I will continue using afterburner for manual oc). I just want to change the max voltage limit of my bios via Maxwell Bios Tweaker and flash it to my card via Nvflash. Is it possible to just mod only max voltage limit? Because I read somewhere that it will cause issues with driver and bios. Is that true? If it is possible, what should I change from voltage table, so the card can go up to 1.237 instead of 1.212 under load. Sorry if it is the wrong place for this thread, I am also new to the forum. I also tried searching but since Gtx 950 is a budget card, I couldn't find much info. Thanks for any advice.
1 - 1 of 1 Posts
