GTX 970s can only use 3.5GB of 4GB VRAM issue
292K views 3K replies 335 participants last post by  Zaine
#1 ·
"Going beyond 3.5GB vram usage ... severely degrades the performance, as if the last 512mb is actually being swapped from the RAM."
980 works fine in comparison.
Guru3D thread here:
here
Reddit hardware thread:
Example:
In Far Cry 4 @ 1440p
No AA: 3320MB Max Vram, locked at 60 fps
2x MSAA: 3405MB Max Vram, locked at 60fps
4x MSAA: 3500MB Max Vram, 45-60fps
8x MSAA, starts around 3700-3800MB @ 4-5fps, stabilizes at 3500MB @ 30-40fps.
#2 ·
I'm going to test this out also this is interesting.
#3 ·
Hmm.. i must say that i have never seen mine reaching 4GB just yet.
#4 ·
I have Far Cry 4 up and running in 5760x1080.
with no AA im getting 3602 to 3700ish. i even saw it hit the 3800's
2xMSAA, the low went to 3675, but still about the same as no aa
keep in mind, i did see it go down to 3500 on both settings in calmer areas.
anything above that was completely unplayable.
edit:
this is with 2 in SLI
and with no AA im getting 60-80fps, 2xMSAA 45-60fps area
#5 ·
Just tried on Siege on BF4.
I usually run 150% and 2xMSAA which gives ~2700MB usage. Bumped this to 200% and 4xMSAA and it ran at 3300-3400MB, but that's as high as I could get it.
Just to confirm this thread is about lower performance after going >3500MB right? Not that the cards can't actually do >3500MB?
#6 ·
Its the cards aren't playable above 3500.
but mine seam to have a 3800 cap, then the fps go to the sub 5-10 range.
maybe is just the 5760x1080 res.
i noticed i forgot to mention my fps in my first post, but i fixed it.
#8 ·
I didn't believe this at first, but I just decided to try and test it myself with texture modded Skyrim and my SLI 970s. I tried to push the 3.5 GBs barrier by downsampling it from 5120x2880 with the four following experimental conditions:
1. No MSAA applied on top
2. 2xMSAA applied on top
3. 4xMSAA applied on top
4. 8xMSAA applied on top
Since MSAA is known to be VRAM heavy, it made sense. I also kept a close eye on GPU usage and FPS with the Rivatuner overlay as well as VRAM usage. All of this was done running around Whiterun to minimize GPU usage. My results were as follows.
1. Skyrim peaked at about 3600 MBs in usage with occasional brief hitching while loading new textures in and out of VRAM. GPU usage remained well below 99% on each card.
2. Skyrim once again peaked at about 3600 MBs with the mentioned hitching, this time somewhat more frequently. Once again, GPU usage remained well below 99%.
3. Skyrim yet again peaked at about 3600 MBs and hitched much more prominently and frequently at the same time as VRAM usage droppped down 100-200 MBs. GPU usage was below 99% again with FPS still at 60 aside from those hitches.
4. Now Skyrim was using the full 4 GB framebuffer with massive stuttering and hitching from a lack of VRAM. This time, I had to stare at the ground to keep GPU usage below 99% and retain 60 FPS. I ran around Whiterun just staring at the ground and it remained at 60 FPS except with those massive hitches where GPU usage and framerate temporarily plummeted. This last run merely indicated that Skyrim can indeed use more VRAM than it was with the previous 3 settings and so the issue seems to be with the 970s themselves rather than just the game in this example. The performance degradation aside from VRAM was severe, but that could just be 8xMSAA at 5K taking its calculative toll.
So it seems to me that my 970s refuse to utilize above ~3600 MBs of VRAM unless they absolutely need it, but I've no idea why. Nvidia didn't gimp the memory bus in any overly obvious way from the full GM204 chip therefore the 970s should have no issue using the same VRAM amount as the 980s. I don't like what I see, it's like the situation with the GTX 660 that had 2 GBs but could only effectively use up 1.5 without reducing its bandwidth to a third, so it tried to avoid exceeding 1.5. The difference is that was predictable due to the GK106's 192-bit memory bus, there's nothing about the 970's explicit specifications that indicates the same situation should apply.
A similar shortcoming was noticed sometime back regarding the 970's ROPs and how the cutting-down of 3 of GM204's 16 SMM units affected the effective pixel fillrate of the 970s despite retaining the full 64 ROPs. It's possible that Maxwell is more tightly-connected to shader clusters and severing them affects a lot about how the chip behaves, but that doesn't really make sense. If this is an issue, it's almost certainly software-related. I'm not happy regardless of the reason and I'll try more games later. Anecdotally, I have noticed recent demanding games peaking at about 3500-3600 MBs and can't actually recall anything going beyond that. I didn't pay attention to it or change any conditions to test it.
#9 ·
Why do people keep making this same thread when it has been disproven...
Go play something like Lords of the Fallen and post results. Others including myself have and posted the results in the official 970 thread and others have done this more in depth tests on other forums.
It's simple, some games are currently programmed to use more or all and some aren't at this point in time.
#10 ·
interesting results, subbed.
#11 ·
If it´s like that, why the 980GTX can use more than 3.6GB? For example, my neighbour doenst stuter in COD:AW above 3.6GB and with the same settings i cant play it without massive stuterring both cards above 80fps, i stuter he doesnt, his card is consuming almost 3.8GB my card is sitting near 3.6GB. I suspect is driver related.
#15 ·
#18 ·
Subbed for finding out if this is a wide spread issue with the 970. Have only gotten my 970 to use 3.5GB vram on Far Cry 4 but would still like to keep an eye on this.
#19 ·
well this explains a lot , ive been banging my head of wall for months trying different settings fresh installs etc etc i have stuttering in most games even if i try to lock fps at 60 and use resolution 1080P (shocking) i cant even play far cry 4 on sli as the performance is awfull even though fps are high have been wondering why i only see cards max out @ 3.5gb then came across this thread via nvidea site then guru3d i am also another user that experiances low gpu usage. I think ill probably end up selling these cards now hopefully i can claw enuff money back to buy new card
#20 ·
Sli for most users on overclock.net is still broken on Far Cry 4.
http://www.overclock.net/t/1520430/official-far-cry-4-information-discussion-thread
#23 ·
VRAM limit and coil whine with some models for nVidia, whilst AMD has screen flicker issues. Seems they can't make a fully functioning card for the mid-high end market; maybe it's to force us to get the model up that actually works - it's all about money I guess.
#24 ·
Originally Posted by aka13 View Post
Love how on 1200 pages of the 970 owners thread this is not an issue, but in a thread with 3 fearmongerers suddenly all hope is lost.
Isn't it funny how that works?
Although you have to question how many of those users are actually getting close to using 4gb of vram as it has to be assumed that a good portion of them were coming from 2gb cards, as did i.
#26 ·
I think most people doesnt realize that, i have a 970 for 3 weeks but only playing supersampled COD:AW i´ve noticed the problem, now that i investigated more i´ve found more games with the same problem. If you dont play high VRAM games (Lots of MSAA, SS) you will not even notice it.
