1 - 4 of 4 Posts
Hey guys,
I have a pair of GTX 980's reference.
I'm at a bit of a loss here. I had SLI working fine, and ended up flashing the BIOS on my two cards.
SLI stopped working (disabled in control panel). So I decided to flash back to what I was running, and still no luck.
Cleaned the drivers up and reinstalled, still no luck. The computer says the connector is not installed. Both cards are detected properly however.
Any ideas on what to do here guys? It was working fine before the bios flash, so I can't think there is anything wrong with the connector.
I have been mucking around with the connector a little. I guess what I'm confused about is it was working perfectly before flashing... hence why I don't think that's the problem!
....X....
Are yo sure yo flash both card ? which bios yo flash there ? OC bios ?
drop some pictures from Gpu-z for both card so i can check
1 - 4 of 4 Posts
