so youre sli 670 stock did more then Titan, did you calculate how many fps or % faster they where?
The titan was sitting on 28-30fps average and peaking at 35fps in the initial firestrike sequence.Originally Posted by grandpatzer
did you compare min fps aswell?
Seems like the youtube video is taken down.
How many fps did the 1137mhz Titan do on the first scene, so youre 24/7 sli 670 did 10fps more?
What are youre 24/7 overclocks on sli 670?
Disappointing imo for Titan, it should be slightly less cost then a GTX690, but it won'tOriginally Posted by trippinonprozac
My sli 670 FTW's @ stock stay locked at around 35fps in the same sequence with peaks at just under 40fps.
When I do a mild overclock to 1340mhz core on one of my cards and 1240mhz on the other card I average 40fps and peak just under 50fps in the same sequence.
This testing was done with driver defaults and my CPU @ 4.6ghz.
