GTX260 water cooling block
512 Views 3 Replies 4 Participants Last post by  MartaLualdi
Hello, I was checking some eshops if they sell water blocks for these types of cards, but I saw usually only blocks for 8800GT*. Can you advise me something? Thanks
1 - 4 of 4 Posts
Just make sure that you get the right block for the card. The 55nm version and 65nm version of the card will use different full cover blocks.
Another thing you can do is the D-tek Fuzion GFX block with the little unisink kit as well.
Block: http://www.dtekcustoms.com/index.asp...rodID=222&HS=1
Unisink: http://www.dtekcustoms.com/index.asp...ROD&ProdID=223
Both of those are very very nice as well, some people prefer the EK block listed above or whatever, just personal opinion really, but I really like D-Tek ^.~
1 - 4 of 4 Posts
