GTX280 Give Two Colors On Monitors?
1144 37
Uhh crap is my GTX280 bad? (See pic)
Yes, I've switched the cables around, and tried different adapters, it always happens on the same output.
I checked it for obstructions as best as I can, and it's still doing this.
1 - 20 of 38 Posts
OG
Is the green monitor set to 32bit color?
Could be about to die.
Edit: whoa said exactly the same thing as me
Reactions: tpavur
try the other screen on your video card on that output. It could be the card.
Its not the 280. I think its either the monitor or a setting in windows. Make sure that windows didnt install any color profiles on your machine. If it did then delete it and the driver for your monitor. It always makes funny colors when monitor drivers are installed with nvidia cards for some reason. Then again, it could just be the monitor going bad.
EDIT: I suppose it could be the 280 if on of the DVI output pins got dislodged or broken or some connection lost. I doubt its the GPU, most likely some pin or connection on the PCB.
It's NVIDIA. The green is to remind you of that.
Reactions: AMD+nVidia
Discussion Starter · #13 ·
That is what I am thinking. But now that you mention the color profiles and whatever, I'm thinking that it might be 7 because I think I used that port back when it was in a folding Rig. However, 7 ALWAYS has the green tint from that port.
Wait, it looks like that in the BIOS also. I think the GTX280 connector might be damaged.
Can I RMA it for that? It's almost brand new...
Discussion Starter · #15 ·
Originally Posted by jrharvey View Post
Inspect the DVI pins on the back and see if any are bent or broken. Now that i have read the whole thread I do think its the 280 most likely OR a configuration in windows.
I checked as best as I could, and I can't see anything.. not saying that it's not there though.
Lol no really?
Woooooaaaah there buddy. Ill have you know that my acer is one of the best LCD monitors I have ever used. Its not the monitor, he switched outputs and it proves the monitor is fine.
Chill, I just reported it and moved on.
Discussion Starter · #17 ·
Originally Posted by grunion View Post
No matter what you do the right monitor is always green?
No lol!
The left PORT on the GTX280 is always green! Both monitors work fine plugged into the right port!
Originally Posted by justarealguy View Post
Have you tried a different source to that monitor? It could be the monitor itself.
Read OP!! I've switched the cables out and everything!
Where in the source does it say you've used a different input to the monitor? It says you've used different cables and adapters. It doesn't specify what type of adapter. I was assuming a DVI->VGA adapter. If you meant graphics adapter (card / accelerator) then please specify and don't blame people because of your vague post.
if its like that in the BIOS then I am gonna say 90% sure its the 280. I dont think its the GPU itself but somewhere a connection to the DVI port got fried or dislodged. If you have in fact tried different DVI cables then that is my final answer. I would talk to PNY and get an RMA. I doubt there is anything you can do unless you are REALLY good with electronics. Most likely its somewhere on the PCB itself and messing with that will surely void your warranty.
1 - 20 of 38 Posts
