GTX285 SLI + Matrox TripleHead2Go + Vista 64 Works! !56K!
8491 Views 39 Replies 26 Participants Last post by  mtbiker033
17
Finally got some time to get it all together and I can confirm that GTX285's in SLI + Vista 64 Ult + 3 22" Dell 2208WFP work at 5040x1050
If you dont know what the Matrox TripleHead2Go Digital is .... Basically its a signal splitter for DVI output from your video card and allows a single DVI port to run three seperate monitors. See more here
Screeens below are at 5040x1050 and 3840x1024 as some games I havent config'd correctly yet
The unit on floor:
Left 4 Dead:
Far Cry 2:
Crysis Warhead:
Far Cry Quick Bench
My Desktop
1 - 20 of 40 Posts
Also you'll need to get the Beat Matrox Powerdesktop for it to work with new nVidia drivers at 5040x1050 & Vista
Contaact the and theyll email it to you while your on phone.
Benches are around 30-60 fps in Crysys Gamer 4xAA , 80+fps in every other game maxed out so far.
o.o ok now I want a monitor that wide... not three monitors just one really wide one XD
FFFFUUUUU....That is insane! How much was that set up??!!
Monitors & TH2Go were about $700, and as long as you already have a powerful nVidia cpu your set
Unbelievable. The issue I see is with your keyboard being so close some of that peripheral has to go to waste
+1!
I duno why but Farcry 2 looks terrible with th2g. Other than that everything's perfect.
You're gonna have so much fun, until this happens:
fffffuuuuuu
fffffuuuuuu
LOL it already happened LOL
Its somewhat annoying at moments like that , but overall the field of view in the periphereal is awesome
This just rocks.
That is all.
i have 2 monitors 1920x1200 and 2048x1152 windows xp and a 9800gx2 and a gtx 260 would i be able to run L4D like that?
or would i need to buy the signel splitter? which costs £120 lol
*edit* how good is porn on that thing?
and here is a pic of my desk top
You could use a peice of software called softH which does a similar thing without hardware. It requires two graphics cards and does not support SLI/xFire and unless your on some serious hardware kills framerates, which is why I went with the TH2GO Digital
i i bought the THGO would i be able to have my
gtx 260 and 9800gx2 working at once on the same thing both connecting to the TFGO? then the TFGO connects to the monitors?
Well since they are diff gpu families you wont be able to SLI them
But you could set up the 9800gx2 as your primary GPU and use the 260 for PhysX. Then connect one dvi from the 9800GX2to the TH2GO and then to three monitors.
ah ok i currently have 2 monitors with differnt resol (1920x1200 and 2048x1152)
would be able to have a task bar across the bottem of both of them? or do i need them to be the same size for that
if i bought the THgo would i be able to have all my games across both my 2 monitors? does it actuly render more or does it just strech the image across?
do you see a drop is fraps per seconds compared to just letting windows vista sort it out and no THGO?
that is just amazing.. for people that can't have that. Wait for this to come soon.
I'd love to see a video of yours running though. looks great man.
http://ces.cnet.com/8301-13855_1-9842798-67.html
Working progress on brightness, but it will be released this year IIRC
http://www.amazon.com/gp/blog/post/PLNK2KGB50Z2XN55D
video on second block is cool.
1 - 20 of 40 Posts
