1 - 20 of 22 Posts
Well I seem to be having some problem with my 470 during games. In Furmark it doesn't seem to break 90-95c, but when I start up Crysis, or Mafia 2 my card seems to overheat and then I'll crash to desktop and check HWMonitor and MSI AB, just now it reported 109c. The card is at stock clocks and I've even tried replacing the TIM with mx-3. Should I just return the card and go to my spare GTX460?
are you having the fan on auto ? if yes grab msi afterburner please
How is the airflow in your case?
What are your idle temps? have you increased the fan speed at all?
Discussion Starter #4
Fan speed is at 70% and the case side-panels are off.
Edit - Idle temps are around 45-50
Edit 2 - Every other case fan is running 100%
Crysis shouldnt run as hot as Furmark in my experience at least. It probably does require lots more VRAM which could be the reason why your card is getting hot. Something might be wrong with the VRAM. This is only speculation on my part. Do you get artifacts?
100c is unacceptable for stock voltages.
I would return the card and get a new one and save yourself the hassle of troubleshooting.
I was going to say bad sensor but you said that your computer crashes when it reaches 100. This leads me to believe that the sensor is not faulty
yea return it. ask for them to do it free of charge too and they may
Discussion Starter #8
No idea on the ambient temps, sorry. But it is quite chilly right now. I'm actually shaking as I type this.
Edit - No artifacts at all
Jayce
Holy crap...100 celsius?! At 70% fan speed? That's crazy.
Now unless your case has absolutely the worst airflow known to man (or none at all), then there is NO WAY that those are normal temps.
There have been quite a few people here on OCN who have posted similar threads about Fermis running WAY hotter than the norm, and in most of those cases those people RMA'd/returned their card and got one that was fine and had much better/normalized temps. I'd suggest that you do the same, OP...save yourself the hassle, time and the worrying.
Just for reference, my top-slotted 470 that's starved for air because of my SLI/Tri-Card setup never even comes close to 90 celsius at 75% fan speed, and I've got it overclocked to 790/1580/1800 @ 1.050 mV.
Need "MOAR" airflow.
Also, AB does nothing about this sort of thing.
At 100C, on Auto, the fans should be redlining their RPMS @ 100%.
something has to be wrong... i have never seen my 480 go past 70% fan and it hasn't even hit 90Deg C with my OC in my sig........
MEGABYTE ME
DO NOT run any other HW monitoring program with AFB or Precision. This has happened to me a couple times now. What happens is with more than one program polling the GPU something bugs out and freezes the fan speed to a much to low value. I had my 480 to 108c 3 times before I figured this out. It happens at random to not every time
http://www.newegg.com/Product/Produc...82E16811112279
If that is your case then it might be airflow. I am sorry to tell you but with only 1 80mm fan as exhaust is not going to cut it for any graphics card of the modern era.
Still that is a bit hot might be a bad seat if you re-timmed it. Maybe redo it if you have not already. Then send it RMA.
OMG someone put a 470 in that?????? hm.... toasty..... i mean it could be done with some mods so it had more fans....... but stock......... even with the sides off
RGB Numba Wan!
This may be nit-picking but running a hot card like the gtx 470 in that case you have is worrisome, either should have gone w/ a bigger case or a cooler card imo. my cards easily hit 70-80c while gaming w/ fan speed @ 60%. With that small htpc case, the air inside is going to warm up really quick and your gtx 470 will have a hard time cooling itself. have you tried running it outside to see what happends? if you dont have any improvements it could be a bad card, if you do, I would highly suspect not enough airflow in your case. good luck
Programmer
Even with bad airflow, no way should you be hitting 100c. RMA.
MEGABYTE ME
Im confident that its HWmonitor and AFB running at the same time. Its some kinda polling bug that overheats the card by either stopping the fan or freezing it to low RPM's. No other software capable of polling the GPU should be running with afterburner. This is somewhat of a common issue that I have not only read about several times now but experienced myself
Discussion Starter #20
Guys, I already said I have the side-panels taken off the case. And the 80mm exaust was swapped out for a Scythe S-Flex (the 2.8k rpm one).
Edit - I'll try out your solution Captain
1 - 20 of 22 Posts
