1 - 5 of 5 Posts
How can i get my 480's fan to over 92%?
Plain and simple.
It only seems to go to 92%, dont know why, anything i can do about it?
Knows the Song of Time
Plain and simple.
Download a more current version of whatever overclocking software you're using. Or you could take it as a sign that your computer is trying to save your hearing.
Lol, i play music literally 24/7, and theres no way i can hear this card over my music...
According to GPU-Z the fan can't go over 92%, I'm sure it's the same on the latest version but Afterburner says it's at 100%
*Edit*
nevermind, I just tested the latest GPU-Z and it shows 100%, I'm not sure when this got fixed. Or maybe it got fixed in the driver. I'm also using the 260.52 driver
Discussion Starter #5
Im using afterburner vs 1.6.1, ill upgade after this nxt wu is done, hopefully that will fix it, ya its at "100%" in afbrnr but in gpu-z it says 92%
1 - 5 of 5 Posts
