1 - 1 of 1 Posts
⤷ αC
After dealing with the craziness I thought it would be a good to have it recorded for posterity. For people that don't consider GUI-less vim to be a user-friendly text-editor.
1. Check the installed packages. You should have boinc from Manjaro's pamac (GUI for XFCE) or pacman (commandline), do NOT install boinc-openrc. boinc-nox is the GUI-less version and is mutually exclusive from boinc
If not, install BOINC. in Terminal type
sudo pacman -S boinc
This uses commandline based pacman to install the boinc package
2. Kill boincmgr via xfce taskmanager (I find this easier than hunting down process ID)
3. Navigate to /home/ and delete gui_rpc_auth.cfg if it exists
4. In terminal type
sudo usermod -a -G boinc $(whoami)
A. add yourself to the boinc group in order for the manager to connect
sudo systemctl enable boinc.service
B. this auto starts BOINC on reboot
sudo systemctl start boinc.service
C. this starts BOINC
sudo gpasswd -a $(whoami) boinc
D. this adds your username to the user group for boinc, this is a fail-safe since the first method in step 4A may not always work for whatever reason
ln -s /var/lib/boinc/gui_rpc_auth.cfg gui_rpc_auth.cfg
symbolic link to the configuration file (GUI RPC password to be exact)
sudo chmod 640 gui_rpc_auth.cfg
E. add read permissions to the config file
some people advise using chmod 644 to solve the issue of "unable to connect to core client" (see https://bbs.archlinux.org/viewtopic.php?pid=1467343#p1467343) but that is because they did not do the step of adding to the boinc usergroup since that gives read permission to users not in the group: "6" is read/write for owner while "4" is read permissions and "0" is none (or no permissions)
5. Reboot
6. open boincmgr and see if problem persists (in the applications menu) or via terminal (not advised since closing terminal terminates it):
boincmgr
7. If it works, proceed to use boincmgr as you do in Windows. Be sure to add yourself to the OCN team if you did not already
FOOTNOTE
The italicized text is explanation. I'm sure most people want to know what the code does.
Pictures required...
It seems Arch-based Linux is still in its infancy for BOINC since the wcg page only lists Red Hat (inc. Fedora) / Debian-based (inc. Ubuntu)
1 - 1 of 1 Posts
