Ok, so I've noticed that there has been alot of discussion about heatpipes here on OCN. Ranging from what is inside of them and how they work, to which design is better and how many you should have. Because of this, I've decided to write this guide.
So, while not an "expert" on heatpiped coolers, I do have a pretty good handle on how and why they work so much better than their non- heatpiped counterparts. So I'm going to do my best to explain things in a very simple, and hopefully easy to understand fashion, that should help dispel some of the "myths" that surround these copper beauties.
First off I should start with the basics (really basic). We all know that we need a heatsink on our CPU. The reason a heatsink works, is because they increase the surface area where the CPU can dissipate its heat. So in general, the bigger the heatsink, the better it will perform, just because its got the law of physics on its side.
ok, so a "traditional" (aka non-heatpiped) heatsink fulfills that requirement just as well as any other heatsink does (Sure, they've got alot of surface area) but they run into one major problem that limits their effectiveness, especially as they get really large. The problem is simple, there is only one place where all of the heat comes from, and therefore only one point of the cooler that is really being effective. In other words, there is only really one "hot spot" from which all of the heat is radiated. Here is an example of what I mean.
Ok, so now that we can see why the traditional heatsink design has its limits, we'll get to why the heatpipe cooler beats it so badly.
A heatpipe is actually something very simple. Its a hollow copper tube, that is filled with just a tiny amount of liquid (usually water, or a alcohol/argon mix).
How they work is pretty simple too. The liquid is all pooled at the bottom, and then its heated up (in our case, by the OC'd CPU). The liquid vaporizes, and absorbes a huge amount of heat by doing that (that gets into chemistry, and I wont go there right now... just accept it). As the vapor rises it is cooled, and eventually condenses (releasing alot of energy) on the inside of the heatpipe and drips its way back to the bottom. Other times, they have a "wick" on the inside that allows the liquid to move even if the unit isn't positioned vertically. (Which is why benchmark reviews tests the coolers both vertically as well as horizontally, because some actually perform better positioned a certain way).
[EDIT: Benchmark reviews no longer performs both the vertical and horizontal positons, as of the latest round of cooler testing {Best CPU cooler: Q3 2008} Most likely because most people that will purchase one of these, will use it in their tower PC, and it not doing it cuts his work in half, since one of the testing steps is eliminated]
Here is an example
And here is a animated GIF of how this works (compliments of theCanadian, he found this for me)
Notice that the heat goes to the end as a gas, then condenses onto the walls of the heatpipe, and flows back to the bottom, to repeat the cycle again. Basically, a heatpipe is air powered phase change cooling. The fan cools off the gas and condenses it instead of a compressor like in traditional phase change cooling.
So if I lost any of you in those paragraphs, or with that picture, just remember this. A heatpipe is basically a superhighway for heat. There is hardly any resistance to the thermal transfer inside of the pipe, and so that allows the heat to be transported somewhere else to be taken care of.
As you can (hopefully) tell from this picture, you can see how heatpipes allowed the heat to be effectively transported to another location, so that there is now 6 "hotspots" instead of just one. This means that the heat can be dispersed much faster, because its not concentrated in just one spot like it was before.
The last topic that I want to mention is that of HDT coolers. The reason that HDT technology makes coolers more effective, is that there isn't any excess thermal transfer going on, through material that really doesn't need to be there. In case you didn't know, each time heat is transferred from one substance to another, some of the efficiency is lost (which is why we use the least amount of thermal paste that we can, because to much of it will hurt the thermal transfer... basically making a wall of paste). So in a HDT cooler, the heatpipes contact the CPU directly, making it that much more efficient, and allowing them to use less heatpipes (this is how a OCZ vendetta 2 or a Xigmatec HDT S1283 can compete with a TRUE).
For a nice little comparison, look at this HERE and HERE. Notice that the HDT coolers consistently outperform their traditional rivals with stock fans, but after a High CFM fan is added, then they are outperformed by few of the more tradition styles, although they still do quite well.
Well, I think this pretty much wraps up my "guide" about heatpipe coolers. If you find things that are wrong, or you you'd like me to provide more detailed info just let me know, and I'll do my best to deal with it in a timely manner.
Hope this helped clear up some confusion, or maybe just enlightened a few of you out there.
EDIT:
Recently I have been thinking about expanding this guide, or creating another to cover the other topics. However, I was thinking about this, and then I saw retrospekts guide, that covers much of what I was going to cover. So I would advise all of you to at least go check his out if you're wanting to read more.
And thanks again for everyones support, I'm glad that you all like it
Here is an example
EDIT:
