[Guide] How to access appdata quickly & easy
110522 7
A quick way to access: C:\\Users\\[user]\\AppData\\Roaming.
1. Go to any windows explorer window (my computer, my documents, my pictures, ect).
2. Type "%appdata%" without quotes, and hit enter.
It will take you directly to that folder.
A quick way to delete the data for an EUE
Edit:
Additional commands (Thanks Ictinike)
Variable                        Typical value (May vary, depending on system)
%ALLUSERSPROFILE%     C:Documents and SettingsAll Users
%APPDATA%                 C:Documents and Settings{username}Application Data
%COMPUTERNAME%       {computername}
%COMSPEC%                C:WindowsSystem32cmd.exe
%HOMEDRIVE%              C:
%HOMEPATH%              Documents and Settings{username}
%PATH%                     C:WindowsSystem32;C:Windows;C:WindowsSystem32Wbem
%PATHEXT%                .COM; .EXE; .BAT; .CMD; .VBS; .VBE; .JS ; .WSF; .WSH
%PROGRAMFILES%         Directory containing program files, usually C:Program Files
%PROMPT%                  Code for current command prompt format. Code is usually $P$G
%SYSTEMDRIVE%          The drive containing the Windows XP root directory, usually C:
%SYSTEMROOT%          The Windows XP root directory, usually C:Windows
%TEMP% and %TMP%    C:DOCUME~1{username}LOCALS~1Temp
%USERNAME%              {username}
%USERPROFILE%           C:Documents and Settings{username}
%WINDIR%                   C:Windows
Reactions: markt
1 - 8 of 8 Posts
Fettered Firewall
Yep.. Nice find but there are more
Not to steal your thunder Mort but just an addition to your excellent post
%HOMEDRIVE%              C:
%WINDIR%                   C:Windows
Of course some of these are used more in DOS mode or for batch/VBS scripts.
Reactions: mortimersnerd
Cool, I'm glad it's useful. I was getting tired of going through the folders to get the the Roaming folder...
Discussion Starter · #8 ·
Originally Posted by nafljhy View Post
very true.. it does get annoying. i got fed up with the appdata folder so i got rid of it.
LOL. I don't think that philosophy is the best, especially when it comes to computers.
"Vista wasn't working right so I just formatted the h/d"
1 - 8 of 8 Posts
