1 - 6 of 6 Posts
⤷ αC
Version: Fedora-Workstation-Live-x86_64-25-1.3
Seeing how yum is deprecated ...
Warning: Your user MUST be in sudoers (i.e. an administrator user)
1. In terminal, install packages
sudo dnf install boinc-client boinc-manager
2. start boinc service
sudo systemctl start boinc-client.service
3. add user to boinc group
sudo /usr/sbin/usermod -G boinc -a $(whoami)
4. add read/write permission to group users
sudo chmod g+rw /var/lib/boinc
sudo chmod g+rw /var/lib/boinc/*.*
5. symlink as per Berkeley
ln -s /var/lib/boinc/gui_rpc_auth.cfg /home/username/gui_rpc_auth.cfg
same as
ln -s /var/lib/boinc/gui_rpc_auth.cfg ~/gui_rpc_auth.cfg
6. logout and login again
7. start client service
optional: auto-start on boot
sudo systemctl enable boinc-client.service
POST INSTALL
8. open client
9. Add projects
10.Remember to add your user to the overclock.net team
Reference http://boinc.berkeley.edu/wiki/Installing_BOINC_on_Fedora
Note Fedora seems more bloated resource-wise,I get about 30% lower BOINC built-in Dhrystone (integer) & about 10% less Whetstone (floating point) benchmarks than Mint (Debian based) / Manjaro (Arch based) but subsequent testing with newer kernel & pausing all other virtual machines resulted in 5-10% lower. This may partly be due to the 7.6.22 BOINC version downloaded from the repositories. In addition , there seemed to be a 10% decrease in points per hour for the few units I crunched in Skynet POGs in Fedora 25 with the default GNOME.
July 10th edit : Fedora 26 is coming this month out of beta. Will likely update this to be more thorough , possibly with the "Spins" that replace the bloated GNOME with other desktop managers
https://spins.fedoraproject.org/en/
* KDE plasma < 1.4GB target
* xfce - lighter weight , but still comes with Firefox < 2GB target
* lxde - lightweight < 700MB target
* MATE Compiz - more graphical < 1.5GB target
* Cinnamon < 1.5GB target
* SOAS - meant for LiveUSB < 700MB target
Target size per https://fedoraproject.org/wiki/Releases/25/Spins
Using the commands in this guide under Fedora 26 beta results in BOINC 7.6.22 still being installed instead of a version 7.6.33 so I guess Fedora is behind. Also it seems BOINC benchmark gets at least 10% less floating point and 30% less integer , just like in Fedora 25.
⤷ αC
Discussion Starter · #2 ·
Confirmed working on Fedora 26 lxde (installer Fedora-LXDE-Live-x86_64-26-1.5);
Fluffy Fennec Foxes!
⤷ αC
Something I tried if the username lacks full admin rights (i.e. not administrator then not in sudoers)
su root
replace ocnuser with your username for below code
/usr/sbin/usermod -G boinc -a ocnuser
add your group permissions
ln -s /var/lib/boinc/gui_rpc_auth.cfg /home/ocnuser/gui_rpc_auth.cfg
Add the autostart on boot , without this step if you restart the PC (not logout and login) it will fail to connect to BOINC settings and be "unable to find the cc config"
Make sure to exit from root level access!
exit
log out and back in
Tested on Fedora core 27 lxde [4.13.9-300.fc27.x86_64] , BOINC version installed through dnf is 7.8.4
⤷ αC
Discussion Starter · #6 · (Edited)
Confirmed working on Fedora 28 (released May 1st)
BOINC client installed is 7.9.3
I don't want to edit the original post because every spoiler will turn into a big mess. :(
1 - 6 of 6 Posts
