Overview
Following my previous guide found here, I now decided to write up another one.
It's just a basic guide on choosing the right TIM for your CPU.
Any suggestions or inputs will be appreciated.
TIM (Thermal Interface Material)
So we all know TIM is the key element to achieving perfect temps.
I have listed various TIM's that will help you achieve lower temps than stock generic TIM.
Different Types of Substances
Aluminum Oxide - Aluminum Oxide is considered to be the best substance used for TIM. It presumed the highest quality since it has no curing time and has a high thermal conductivity. The materiel is easy to apply and spreads out easily.
Polysynthetic Silver - This type of materiel used is very electrically conductive, meaning it might cause harm to your hardware if you happen to spill some. Polysynthetic Silver almost always comes with a cure time and can range from 10minutes to 200hours.
Silicon Oxide Grease - Silicon Oxide Grease is considerably low quality TIM, it is usually made out of the stock generic TIM. However, there are some top quality brands made out of this substance, like TX2. This type of TIM can sometimes come with a cure time but usually not. This type of materiel also thermal conductive meaning the heat transfers well.
Now onto the TIM
Aluminum Oxide
NOTE
Before you apply TIM, it is always best to put your TIM in a cup of warm water for 10 minutes, that way. The TIM spreads out more easily resulting in better application.
Method of applying TIM
Heres a quote from benchmarkreviews on the TIM applications.
HDT Coolers
As for HDT Coolers, heres the best method of apply TIM.
The method can be found here.
End
That concludes the TIM's that I personally thing are good, these are just my personal preferences. If anyone has anymore suggestions to add, feel free. Rep+ to all that help.
In case you need to see any reviews, heres a comparison of all the TIMS.
EDIT: I will be adding pictures and more specific info tomorrow morning
Now onto the TIM
Aluminum Oxide
- IC7 - In my opinion, one of the best TIM out there. This stuff is amazing, there is no cure time and works instantly, I've seen quite a few people getting lower temps switching from AS5 to IC7. Highly recommend this TIM. IC Diamond is composed mostly of diamond powder (92%), and as such is quite thick. This high viscosity is by design for increased reliability and it is what makes it application procedure different. Lord Xeb has released a guide on applying IC7 and can be found here
- Shin-Etsu X23 - My personal favorite, although its rare, this TIM is amazing, like the previous TIM I listed, there is no cure time and the stuff spreads like peanut butter. It's thermal conductivity is 6.0 W/m K, much more conductive than your average TIM including IC7 !
- OCZ Freeze - I think we all know what this TIM is? This stuff is amazing, I have it running on my E6300 and it dropped my temps by 8C switching from the generic TIM intel has provided with. There is no cure time so, it instantly starts working. Highly recommend this TIM.
- Artic Cooling MX-2 - Also very good TIM, MX2 has no cure time so it also starts working when you apply it. I've heard many great things about this TIM and many people some to get great results from using this TIM.
- Shin-Etsu G751 - This TIM is very similar to the X23, it's very thermal conductive and I've seen great results using them. However, X23 has proved to be a little better. But, I still recommend this TIM as Shin-Etsu is top quality.
- Matrix II - A new TIM on the market, recently an OCN member (spaceballsrules) reviewed this TIM. Apparently, the Matrix II has no cure time and beats the MX-2 in temps.
Arctic Cooling MX-2: 33*C idle/ 45*C load
Matrix II: 31*C idle/ 44*C load
- Gelid GC Xtreme - Currently outperforms OCZ Freeze by 4C on load. You can find a review on the new TIM here. As for the TIM itself, it is very thermal conductive and has no electrical conductivity. There is also no curing time meaning it works right when you apply it.
- Artic MX-3 - As an upgraded version of the award-winning ARCTIC MX-2, the performance of the ARCTIC MX-3. This new compound is composed of carbon microparticles which lead to an extremely high thermal conductivity â€" 8.2 W/mK. The TIM is non-electrical conductive and has a high thermal conductivity, the TIM also has no cure time.
- Artic Silver 5 - We all know what this TIM is. AS5 used to and still is the most commonly used TIM for the average computer user. This TIM kept my temperatures at a very nice point. However, the TIM is very hard to apply and can be result to spreading over your hardware. The downside to this is that AS5 is electrically conductive meaning your hardware can be damaged if the TIM comes in contact. It also has a cure time, which can range from 10hours to 200hours. It took me 3 days before I started to notice temperature drops. This TIM is good but not the best, I still recommend this TIM if you are wanting to try it.
- Tuniq TX-2 - This is considerably the most popular TIM made by this time of substance. The TIM is easy to apply and has a high thermal conductivity meaning heat transfer well with this TIM. There is also no cure time meaning the the compound works right after applying it. This TIM also has no electrical conductivity therefore you should have no worries about damaging your hardware. I highly recommend this TIM to anyone in the market looking for good TIM
- Thermalright - Chill Factor - This TIM is not very common amongst people but it is great! The TIM spreads really easily and has no cure time. Its very to clean after and the stuff is very thermal conductive. I recommend this to anyone in the market looking to try a new TIM.
- Tuniq TX-3 - Tuniq TX-3 - Brand new TIM on the market, like its brother. The TX-3 has no cure time and is very thermal conductive. It's non sticky and spreads easily, Tuniq TX-3 is said to preform better than both Thermalright Chill Factor & TX-2 so I would highly recommend this TIM to anyone.
- Scythe Thermal Elixir - The TIM is very thermal conductive and has no curing time. The TIM also has no electrical conductivity which prevents damaging hardware. A review of the TIM shows that it outperforms MX-2 and AS5. There review can found here. Also, a comparison between a couple TIM's.
- ArctiClean - This materiel perfect for removing the TIM off your CPU & Heatsink, it works instantly dissolving the TIM leaving room for another TIM.
- Tuniq T1-R - Just like ArctiClean, very easy to apply. The TIM dissolves very quickly making TIM removal much easier.
- However, if you do not want to purchase the ArtiClean, you can simply use Isopropyl Alcohol commonly known as Rubbing Alcohol to remove the TIM, make sure you use a napkin or cotton swabs.
NOTE
- Apply a rice size dot of TIM onto your CPU.
- As for quad's, there is also another method you can use. This you would have to apply a thin line of TIM accross the center of the CPU.
1. CPU Cooling products which operate below the ambient room temperature (some Peltier and Thermo-electric coolers for example) should not use silicon-based materials because condensation may occur and accelerate compound separation. 2. All "white" style TIM's exhibit compound breakdown over time due to their thin viscosity and ceramic base (usually beryllium oxide, aluminum nitride and oxide, zinc oxide, and silicon dioxide). These interface materials should not be used from older "stale" stock without first mixing the material very well. 3. Thicker carbon and metal-based TIM's may benefit from several thermal cycles to establish a "cure" period which allows expanding and contracting surfaces to smooth out any inconsistencies and further level the material. |
End
