Hi all I made a guid for unlocking the pipes on NON-ULTRA 6800 guides.
The benifit to this is simple,A 175.00 or less card that keeps pace with the GT for no additional cost ! !
Ok for any 6800 owners and possibly others with nVidaia cards her is a step by step guid to unlock your pipes and shaders Using RivaTuner 15.3 NY.
THIS IS A SOFT MOD NOT A BIOS FLASH OR HARDWARE MOD
Down Load it from here
OTHERVERSIONS Should work as well)
http://downloads.guru3d.com/download.php?det=163
Install it and open it up and on the main menue select Target Adapter and click on the right side of where it says custom. "see pic in link"
http://img.photobucket.com/albums/v87/diehrd/Step1.jpg
Click on the first image of the video card and another window opens that has a tab for AGP and NVStrap Driver.
Select the NVStrap driver tab and at the bottom it will say determined by VGA Bios Expand that box like i did in pic see link.
http://img.photobucket.com/albums/v87/diehrd/Step2.jpg
Set it to custom and it should now show you how many pipes and shaders are in use a 6800 128meg card should have 12 and 5.Now that you selected custom check the boxes to the left that say Allow enabling of hardware masked units and unlock professional capabilities.
(Note my card had 12 pipes and 5 shaders yours may not)
Ok now after you checked those 2 boxes click on the Custom tab that is now enabled as a result of these last changes and you will get this screen.(See link for pic)
http://img.photobucket.com/albums/v87/diehrd/Step3.jpg
Ok now to do a little unlocking
You will see right away on the far right HW masked this refers to hardware masked and it is your locked pipes we intend to now set free.Click on the collum that has the yes associated witrh it and it will highlite the hex Numbers at the top see pic:
Ok a closed pipe or shader is represented by a ZERO we need to change it to a 1,So having already highlited the locked pipe all we need to do is push the number 1 key on the key board Make sure numlocks is on if ya use the numbers on the right side of the key board he he he.
Ok now look and it will now say enabled ,DO the same thing for all hardware masked items and you will have enabled them..You may want to enable one at a time and test the card.
Stock 3D 03 score for this card I got 9223 and
Overclocked with out any pipes and shaderes open 10837
Stock core and Ram with Pipes and shaders unlocked 10637
Over clocked core and ram 16/6 open 11427 (Edit)
Of course any mod can affect hardware adversly.I and many have used this guide with great success,but that does not mean you will . .
