The intention of this thread is to help users of ENB understand the effects and changes brought about by the program and familiarize you to the point where you can fine tune your own presets or even create your own ENB from scratch!
There is a lot of possibility with ENB, enhancing and completely altering the visual dynamics of Skyrim. The beginners guide will cover the main ENBseries.ini and how to add effects such as Film Grain and DoF and more!
The advanced guide will introduce you to a customized effects file called APPS designed for ENB that will greatly enhance your customization options with shader optimizing, HSV controls, multiple Bloom variables as well as teaching you how to customize your own effects such as Film Grain, DoF and Vignettes and much, much more! The possibilities are nearly endless!
And as always, happy modding!
ChaotiKPranXter
Advanced Guide to Tweaking Using APPS (On hold for now)
(WIP)
CREDITS
ChaotiKPranXter - Author
--JawZ-- - Author of the original guide
Lifeshield - Contributor
Aiyen - Contributor
Nexstac - Contributor
If you've ever used an ENB, either from Boris' site or a Nexus preset, then you've seen for yourself how drastically it can alter the visual dynamics of Skyrim completely, whether you want photo-realistic quality, dark and atmospheric, or even more cartoon like, it's all possible. With this larger than life mod, you can easily expand on those dynamics even further, probably 10-20 fold! All it takes is patience and understanding. ENB includes effects to enhance visuals, such as Ambient Occlusion, Improved AA, various lighting techniques, bloom and shader optimizing such as curve and saturation and even a customized day/night adaptation. As ENB has grown and developed further over the years, so has the code, and with it the possible effects to be integrated. This lead to things that have become staples in todays numerous presets found throughout the net, including DoF, vignette styles, and even film grain. These additional effects is where this mod comes into play and really shines!
I've personally spent hours scouring the net for some specific effects I've seen used, only to have to download a preset or two, sift through hundreds of line of code, just to piece together what I want to use for my ENB. With this mod, Kermles has accumulated, with permissions, effect codes from the likes of IndigoNeeko, JawZ, Matso, HelioDouble6 and more, compiled them into one effect file along with some very intelligent codes of his own to create an unequalled powerhouse for ENB's. This file features nearly a dozen different bloom alternatives, many of which can be overlapped, various vignette styles as well as a few shader controllers, palette mixing and variable adaptation alike, all in one! This presents you, the user, near endless possibilities of customization for the game! This is an invaluable tool for anyone looking to create their own ENB, and should not be overlooked!
Caution: This is designed to be used with a fresh ENB version with a clean, unedited enbseries.ini file. The file contained in this mod is a customized enbeffect.fx file that will OVERWRITE any from your Skyrim directory should you have an ENB already installed. It is compatible, and can be used this way, however do so at your own risk, and back up your original file. The use of this will change your preset drastically, altering the intent of the author and your gameplay experience.
ChaotiKPranXter
Note: Some of the terms defined here are relative only to ASSP, where as they will be used primarily if not solely in the Advanced Guide. They will be noted accordingly. Click screenshots to view full size.
Adaptation - Enables an eye adaptation effect when viewing bright objects, light sources. This effect can vary depending on brightness of view subject, facing up or down, and indoors/outdoors. The specific parameters for this are unconfirmed here officially as they seem to differ on many variables.
Ambient Occlusion - Artificial self shadowing of objects in real time. If you choose to disable SSAO in ENB, AO can be enabled through your video card settings. It won't have the same quality or look, but it will be more performance friendly.
Bloom - Creates a blurred glow around light sources and bright objects.
Chromatic Abberation - Simulating the error of a camera, this causes a slightly blurred, colorful edge around objects, depending on brightness transition between the objects and background.
Contrast - This will strengthen or weaken the transition between bright and dark areas and colors, as well as color intensity and saturation
Curve - Inputs a color channel onto a curve "Range, altering the output depending on the plot point, (Curve Value). While this color curve is present in ENB, some settings use Curve values as a Contrast/Blue Shift measure instead. Further explanation can be found in the relative settings.
Day/Night Detection - Variables are adjusted depending on the time of day, increasing/decreasing day and night settings accordingly. Example: This is how you would adjust the look of your sunrise/set
Depth of Field - DoF is an overlay effect that simulates real-life visual focus through blurring the background of a scene, and increasing contrast to draw attention to a focal point. This can be an object or objects right in front of the camera, or even some distance away depending on your values. This has quite a performance hit usually.
Film Grain - This effect is also a cinematic overlay of sorts, but to define it would require a paragraph of very technical jargon that I can't put simply. Wait for screenshots.
Fog Color - Coloring applied to distant terrain or long tunnels in caves similar to a tint, not the same as volumetric fog
Grading - Shifts RGB color channels towards another, specific color, then remixes. APPS
HDR (High Dynamic Range) - Merging multiple exposures of an image to create the appearance of more color than is actually possible. APPS
Hue - "What color is that?" Difference between light blue vs. dark blue, light red vs. dark red, etc. APPS
Image Based Lighting - This effect will make static objects around the landscape appear lighted, while the contrast is increased as well around them, considerably increasing detail and visual quality. This effect greatly enhances the terrain reflections off the water if enabled.
Intensity - Magnitude or strength of color
Lens Filter - Creates a screen filter with a specified color to alter the overall look of the image depending on strength. APPS
Liner Interpolation "Lerp" - This is a technique that tries to fill in the blanks essentially. Given two or more sets of known values, this will create the unknown values in an attempt to seamlessly integrate the sets. Concerning graphics, this can be another way to adapt a low resolution image to a high resolution display essentially forcing a higher resolution of the image. APPS
Note: This, like Curve, can lead to continuous readjusting of values even if tweaked carefully.
Particles - Atmospheric effects like fog, steam, dust and even white water foam that are rendered in real time.
Polarization - Original colors are polarized along the color wheel based on a specified color. The original colors close to the specified will shift towards it, while colors opposite will be accentuated. APPS
RGB/CMY - Red, Green, Blue/Cyan, Magenta, Yellow. APPS
Saturation - How the color appears in different lighting schemes; pale and weak or pure and strong; Similar to intensity
Sepia - Referring to an overlay effect, this creates a kind of lens filter. Originally made with the "Sepia" color itself to create the appearance of an aged, chemically developed photograph. New Sepia effects allow for greater customization with color controls for a wider variety of choices
SSAO (Screen Space Ambient Occlusion) - Real time shadowing of the whole scene in screen. Objects will create shadows on other objects.
Subsurface Scattering - This is a lighting technique that artificially "Absorbs" light into certain semi-transparent materials, in this case skin and vegetation and some objects in order to render a more realistic lighting. This technique is already used in most computer graphics to render realistic lighting schemes in similar situations.
Tone Mapping - Merging multiple exposures of an image to alter contrast and increase details such as completely removing shadows and bright reflections to make the entire image detailed and visible. APPS
Vignette - This effect darkens the edges of the screen in an attempt to fake a higher screen resolution and draw attention to the center. It's most commonly used in the movie industry, and can help create a "Cinematic" atmosphere in the game. The most common example you'll find in movies is referred to as "LetterBox", which is a particular kind of Vignette, creating black bars of varying length across the top and bottom of the screen.
Volumetric Fog - The fog or mist surrounding mountain peaks in distant terrain
This is a guide designed to help people looking to fine tune their current settings or even create a new ENB on your own. There is little documentation thus far on the available options and what they do, so I thought I'd share my knowledge with the community. It can be intimidating at first, especially if you aren't using the GUI that comes with Version .132 or above, but hopefully this guide will help put you at ease and familiarize you with the different ways ENB can truly make your game shine! Of course, everyone's style is different and creativity is unique to us all, so keep in mind the tweaks you make are your's to play around to suit your taste. If I can encourage anything it's to definitely play around with these values until you get the hang of it.
Note: The default command settings and values are based on Version .166, so yours may vary based on which version you use. If the setting is greyed out in the GUI, you either can't alter it, or it can only be changed through the enbseries.ini file.
PROXY SETTINGS:
EnableProxyLibrary=false
InitProxyFunctions=true
ProxyLibrary=other_d3d9.dll
These settings are used if you have another mod, processor or injector that installs a d3d9.dll (DirectX9) file into your Skyrim folder. ENB's are designed to run in tandem with these additional files, but since it will install it's own d3d9.dll file, you have to make them talk to each other or one will overwrite the other. In this case, you would take the non-ENB d3d9.dll file and rename it to SweetFX_d3d9.dll, for example. You would then alter the ProxyLibrary command to reflect the original files new name. From there, change the EnableProxyLibrary command value to true and test it to make sure it works. If it does, you will continue to see the effects of the original file as well as see the ENBDev.com information in the upper left corner during the main menu screen.
Note: The Injector version of an ENB does NOT contain a d3d9.dll file and therefore there is no need to rename the original and alter the Proxy settings.
Note 2: If you use HiAlgoBoost and want to add an ENB, please follow the instructions on the Nexus page in order to make them work, as the steps are different.
GLOBAL:
AdditionalConfigFile=userconfig.ini
UseEffect=true
The Global settings are two part, one is only in the enbseriies.ini file, while the other can also be found in the GUI.
AdditionConfigFile is just what is says, it's used to add an additional config file to the ENB settings. All you would need to do is edit the command value to reflect the name of the config file you want to use.
UseEffect is for enabling or disabling the ENB process as a whole, it can be accomplished by setting true or false in the enbseries.ini, checking the box in the GUI and also by pressing Shift-F12 in game.
FIX:
FixParallaxBugs=false
ForceFakeVideocard=false
IgnoreLoadingScreen=true
IgnoreInventory=true
FixGameBugs=true
FixSsaoWaterTransparency=true
FixSsaoHairTransparency=false
FixTintGamma=false
RemoveBlur=true
These are for the most part all enabled and can be left alone. If you have issues with vanilla hair while using SSAO, you can set this fix to true. If you're using a Depth of Field effect with your ENB, then you may want to enable RemoveBlur, as it will clear the image while in menus, it will not effect normal DoF processes in game however. Enable ForceFakeVideoCard if using an ATI card, leave alone if you use Nvidia.
The biggest fix here to take note of is ParallaxBugs as it can have a hefty impact on both the visual dynamics and performance. Basically this enables the use of parallax textures in game that otherwise wouldn't show. Parallax is similar to Terrain Bump, making the image appear much more 3D such as rocks and mountains and stone paths. Don't bother enabling this fix unless you actually plan to download and install parallax textures such as Project Parallax from the Nexus.
GAME:
SpeedHack=false
If you have trouble incorporating another d3d9.dll through proxy, you could try this. Otherwise, leave it disabled.
Note:"SpeedHack=true - change this to false, will not help in skyrim, but may help against second d3d9 library."
- Boris Vorontsov
MULTIHEAD:
ForceVideoAdapterIndex=false
VideoAdapterIndex=0
ForceVideoAdapterIndex is used to enable multi monitor displays and possibly multiple outputs for one or more video card. This is likely to be used in the case of using different outputs other than your monitor. Adjust the VideoAdapterIndex value as necessary.
LIMITER:
WaitBusyRenderer=false
EnableFPSLimit=false
FPSLimit=30.0
WaitBusyRenderer, if enabled will disallow pre-rendering of frames, meaning each frame will be rendered by the video card completely before rendering the next.
Set the EnableFPSlimit to true in order to cap your total allowed frames per second, the FPSlimit value is how many frames per second max. As best I can tell, WaitBusyRenderer can help with flickering and lighting artifacts caused in game. I've never found a use for it personally.
INPUT:
//back
KeyReadConfig=8
//shift
KeyCombination=16
//f12
KeyUseEffect=123
//home
KeyFPSLimit=36
//num / 106
KeyShowFPS=106
//insert
KeyScreenshot=45
This is simply for assigning hot keys to various commands for easy use in game. Keys are based numerically depending on your keyboard which mainly differs between countries/languages.
ENGINE:
ForceAnisotropicFiltering=true
MaxAnisotropy=16
SkipShaderOptimization=false
This allows ENB to force AF during gameplay by setting the command to true and setting the max number of filter passes. You can use this alongside the vanilla AF in the Skyrim launcher options and even force it through your hardware configurations all at the same time, but you will likely notice a performance hit or lagging, and not much to show for it otherwise. You're best off picking one or the other. SkipShaderOptimization works to debug specific shader compilers. Enable if you have driver compatibilities to possibly solve problems.
EFFECT:
UseOriginalPostProcessing=false
UseOriginalObjectsProcessing=false
EnableBloom=true
EnableAdaptation=true
EnableAmbientOcclusion=false
EnableDepthOfField=false
EnableDetailedShadow=true
EnableSunRays=true
EnableSkyLighting=false
EnableReflection=false
EnableImageBasedLighting=true
These settings is where the fun begins. These commands enable/disable the main effect settings used in ENB such as Bloom, SSAO, SkyLighting and DoF. If you're unsure of what any of these effects add or alter, check the Glossary on the header page for a description. As for the UseOriginalPost/ObjectsProcessing commands, these will use the vanilla post processing technique before the ENBs while ObjectsProcessing is the same, specifically for objects only.. Basically your game will still be able to utilize the effects from ENB, but the visual dynamic from the vanilla game will be retained. Keep in mind, enabling these commands are where ENB really starts altering the appearance of your game, and with it performance. You can lose up to 55% of your performance in some cases with all the effects enabled if they aren't adjusted correctly, so tweak carefully!
Note: Enabling DoF here will not magically create it in game, only enable the use of an external file. You would have to download and install DoF from Matso or Nexus. It will overwrite the enbprepass.fx file and with the above command enabled, viola! The enbprepass.fx file is also where you'd edit values to tweak the look of your DoF, more on that in the advanced guide.
ANTIALIASING:
EnableEdgeAA=true
Again, self explanatory. This enables Boris's personal AntiAliasing code for Skyrim, and meant to be used stand alone. You could theoretically experience lag due to Vram spikes if you have multiple AA processes enabled, however, it is possible to almost completely remove all Aliasing in Skyrim using this as well as hardware settings with the right adjustments, but I've never tried.
BLOOM:
Quality=0
AmountDay=0.25
AmountNight=0.25
AmountInteriorDay=0.25
AmountInteriorNight=0.25
BlueShiftAmountDay=0.3
BlueShiftAmountNight=1.0
BlueShiftAmountInteriorDay=1.0
BlueShiftAmountInteriorNight=1.0
ContrastDay=1.0
ContrastNight=1.0
ContrastInteriorDay=1.0
ContrastInteriorNight=1.0
These are your Bloom values if you choose to enable it. For Quality values on this and all other effect settings in ENB, the lower the value, the higher the quality. From there, you can increase the area of effect from light sources by adjusting the bloom amount during day and night, both indoors and outside by raising the value, and decreasing by lowering it. As for Blueshift and Contrast values, you will need to set these values incredibly high to notice a difference, such as 50.0. I usually leave them alone personally.
CAMERAFX:
LenzReflectionIntensityDay=1.0
LenzReflectionIntensityNight=1.0
LenzReflectionIntensityInteriorDay=1.0
LenzReflectionIntensityInteriorNight=1.0
LenzReflectionPowerDay=2.0
LenzReflectionPowerNight=2.0
LenzReflectionPowerInteriorDay=2.0
LenzReflectionPowerInteriorNight=2.0
These settings effect how light and effects such as campfires, flame and lightning spells, etc. react to the player screen or camera. Raising values here can have dramatic changes, leading to reflective glares in the screen, more commonly known as lens flares. Adjustable during day/night and interior/exterior cells alike. Raising intensity will change how strong the color effects are while power will create larger more noticeable effects or inversely.
SSAO/SSIL:
UseIndirectLighting=true
UseComplexIndirectLighting=false
UseComplexAmbientOcclusion=false
SamplingQuality=2
SamplingPrecision=2
SamplingRange=0.3
FadeFogRangeDay=2.0
FadeFogRangeNight=2.0
FadeFogRangeInteriorDay=2.0
FadeFogRangeInteriorNight=2.0
SizeScale=0.35
SourceTexturesScale=0.35
FilterQuality=1
FilterType=4
AOAmount=1.5
AOAmountInterior=1.5
ILAmount=4.0
ILAmountInterior=4.0
AOMixingType=2
AOMixingTypeInterior=2
AOIntensity=1.0
AOIntensityInterior=1.0
AOType=1
This is where your first noticeable performance hit will likely take place. Orignally when SSAO/IL is enabled, it's set to a performance default, enable ComplexAO/IL to switch to the Quality default. IndirectLighting itself is used to help offset the AO amount applied. You probably won't notice a difference unless you use higher values.
Setting the Quality values lower will increase it while decreasing performance. The increase in quality is hardly noticeable unless you use a very high resolution with high values.
SamplingPrecision will sharpen the shadows created while SamplingRange will adjust the radius created from objects. Lower values will sharpen near distance effects, while higher values will effect longer distances, which will have varying effects on performance.
FadeFogRange is relative to the AO applied to distant fog. The higher the value, the sooner AO effect will fade.
SizeScale/SourceTextureScale adjustments are disabled.
Filter/MixingType values for AO/IL can be reduced to increase quality or increased to increase performance.
AO/ILAmount will increase/decrease relatively with values for interior/exteriors. Higher values will strengthen the shadow effects.
NIGHT/DAY:
DetectorOldVersion=false
DetectorDefaultDay=false
DetectorLevelDay=0.65
DetectorLevelNight=0.25
DetectorLevelCurve=1.0
This is where things can get tricky. These values essentially control how much the day and night values of other settings get implemented during various times of day. DetectorOldVersion will enable or disable the day/night detector used in older versions of ENB, while DetectorDefaultDay will use the vanilla settings. LevelDay/Night values can have drastic changes on your game, and I would usually leave these till after you've got the foundation of your ENB first. Otherwise you may find yourself tweaking these values over and over again as you make other setting adjustments. Primarily speaking, the most direct use for these adjustments would be to control when the sun rises and sets throughout each day, and how they appear based on the values and their amount implemented at the times. This doesn't actually change the time scale in game, rather the way it appears as day and night throughout the time scale you use.
Note: Day/Night settings will have effects well into the next cycle regardless of your Day/Night detector settings, so be prepared. Open the GUI in game, and open the Statistics tab throughout the day or night. It will tell you the applied ratio of day/night settings accordingly based on your settings.
ADAPTATION:
ForceMinMaxValues=false
AdaptationSensitivity=0.2
AdaptationTime=0.4
AdaptationMin=0.1
AdaptationMax=100.0
This is a tricky beast, with a lengthy bit of function, be sure to check the Glossary for further explanation. As for the values, ForceMinMaxValues overrides the user set values for AdaptationSensitivity/Time. Individually, the AdaptationSensitivity is how noticeable the effect will be, or how much the camera will show a reaction to the effect. AdaptationTime is how long the effect lasts and determines the transition speed between light and dark subjects necessary for the effect to occur.The AdaptationMin/Max allow you to control the range off effect. If you want a very slight effect for example, lower the Max to a very small percentage and set a low Sensitivity. The first, and most noticeable effect when this is enabled is the overall lighting to the screen, as this effect will appear to brighten everything.
ENVIRONMENT:
Note: In these settings, the curve values correlate with the intensity values in a similar fashion as the Modifier/Multiplier relationship. You will see results from adjusting the curve/multiplier values even if the intensity/modifier values are 0.0
DirectLightingIntensityDay=1.0
DirectLightingIntensityNight=1.0
DirectLightingIntensityInteriorDay=1.0
DirectLightingIntensityInteriorNight=1.0
DirectLightingCurveDay=1.0
DirectLightingCurveNight=1.0
DirectLightingCurveInteriorDay=1.0
DirectLightingCurveInteriorNight=1.0
DirectLightingDesaturationDay=0.0
DirectLightingDesaturationNight=0.0
DirectLightingDesaturationInteriorDay=0.0
DirectLightingDesaturationInteriorNight=0.0
These values adjust the settings for Direct lighting, or sunlight on a scene and will help intensify shadows. Intensity is light strength, while desaturation values will lessen the colors that are in the effected light. Curve values in this case will alter the contrast to variable levels depending on the intensity values.
SpecularAmountMultiplierDay=1.0
SpecularAmountMultiplierNight=1.0
SpecularAmountMultiplierInteriorDay=1.0
SpecularAmountMultiplierInteriorNight=1.0
SpecularPowerMultiplierDay=1.0
SpecularPowerMultiplierNight=1.0
SpecularPowerMultiplierInteriorDay=1.0
SpecularPowerMultiplierInteriorNight=1.0
SpecularFromLightDay=0.0
SpecularFromLightNight=0.0
SpecularFromLightInteriorDay=0.0
SpecularFromLightInteriorNight=0.0
Specular light is the shine effect given off of objects and surfaces. Power adjusts how much shine you see, while the Multiplier will strengthen the effect based on the Power value. Adjusting SpecularFromLight values will determine how much of the effect is applied to static surfaces.
AmbientLightingIntensityDay=1.0
AmbientLightingIntensityNight=1.0
AmbientLightingIntensityInteriorDay=1.0
AmbientLightingIntensityInteriorNight=1.0
AmbientLightingCurveDay=1.0
AmbientLightingCurveNight=1.0
AmbientLightingCurveInteriorDay=1.0
AmbientLightingCurveInteriorNight=1.0
AmbientLightingDesaturationDay=0.0
AmbientLightingDesaturationNight=0.0
AmbientLightingDesaturationInteriorDay=0.0
AmbientLightingDesaturationInteriorNight=0.0
Ambient Lighting works similarly to direct lighting except this lighting will effect a scene in its entirety, including shadowed areas. Adjust the values here same as you would for direct lighting otherwise. These values are crucial in creating darker nights/dungeons.
PointLightingIntensityDay=1.0
PointLightingIntensityNight=1.0
PointLightingIntensityInteriorDay=1.0
PointLightingIntensityInteriorNight=1.0
PointLightingCurveDay=1.0
PointLightingCurveNight=1.0
PointLightingCurveInteriorDay=1.0
PointLightingCurveInteriorNight=1.0
PointLightingDesaturationDay=0.0
PointLightingDesaturationNight=0.0
PointLightingDesaturationInteriorDay=0.0
PointLightingDesaturationInteriorNight=0.0
Point Lighting is what comes from torches, firepits, etc. These values can effect intensity and radius of the effects, while curve values will adjust the color itself, usually ranging from a yellowish white to bright, dark reddish orange. This how you would go about matching up the coloration on surfaces around the fire, to the fire itself once the curve values in the fire section have been adjusted. Desaturation values here will effect the color saturation cast by the light sources onto people, objects and surrounding surfaces alike effected by the light radius. The values also effect spells that give off light.
FogColorMultiplierDay=1.0
FogColorMultiplierNight=1.0
FogColorMultiplierInteriorDay=1.0
FogColorMultiplierInteriorNight=1.0
FogColorCurveDay=1.0
FogColorCurveNight=1.0
FogColorCurveInteriorDay=1.0
FogColorCurveInteriorNight=1.0
These settings effect the Fog Color, indoors and out, day and night. The multiplier values will adjust the strength of the fog as set by the curve value. The curve value here works to adjust Contrast/Blue shift, depending on the multiplier. Depending on the Multiplier value, the higher the Curve value, the more blue shift added, while the lower the value, the blue shift is removed and contrast increased. This can change from weather type however, where you might see an increased contrast during a sunny day, only to find the same value creates a blue shift during a storm.
ColorPowDay=1.0
ColorPowNight=1.0
ColorPowInteriorDay=1.0
ColorPowInteriorNight=1.0
This simply strengthens/weakens the color application during day/night interior/exteriors. As the application is strengthened however, the effect also darkens the colors and inversely. This works for all color channels in effect, including light sources such as point lights.
SKY:
Note: All of the Curve values are used for Contrast except the Aurora Borealis and Sun, which are actual Color Curves.
Enable=true
DisableWrongSkyMath=true
EnableSky turns the toggles between ENB effects and vanilla sky. Vanilla won't look the same with this disabled if you've altered overall scene brightness, contrast or color. WrongSkyMath in my experience fixes visual errors that can occur when using ENB with vanilla sky.
StarsIntensity=1.0
StarsCurve=1.0
Intensity controls the overall brightness and intensity of the stars and their colors, while curve will alter contrast. Both of these values will alter the light emitted as it effects the clouds, nebula etc. Only exception would be the moon/s.
AuroraBorealisIntensity=1.0
AuroraBorealisCurve=1.0
Values represent the same as stars, only dealing with the Borealis. The difference here is that the color curve is much more noticeable in altering the appearance. Finding a good balance between the two is important when considering the ambient light during exterior/night scenes, as it wouldn't make much sense to have pitch black nights while the Borealis and stars/nebula above shine like the New Vegas strip. I'd recommend adjusting stars first, then Borealis, and fine tuning between the two as stars will have a larger effect on the Borealis then inversely. And adjusting your lighting schemes from there.
CloudsIntensityDay=1.0
CloudsIntensityNight=1.0
CloudsIntensityInteriorDay=1.0
CloudsIntensityInteriorNight=1.0
CloudsCurveDay=1.0
CloudsCurveNight=1.0
CloudsCurveInteriorDay=1.0
CloudsCurveInteriorNight=1.0
CloudsDesaturationDay=0.0
CloudsDesaturationNight=0.0
CloudsDesaturationInteriorDay=0.0
CloudsDesaturationInteriorNight=0.0
CloudsEdgeClamp=0.5
CloudsEdgeIntensity=1.0
The fun part! And... one of the most tedious and frustrating. The latter comes especially prevalent if you use something like CoT or RCRN that adds weather dynamics. Believe me when I say it's incredibly difficult to get every weather effect looking perfect with vanilla's 20+, you can pretty much forget about doing it with 200-500+ weathers when using either mod. This pretty much holds true for the gradient settings below as well.
The intensity here will make the clouds stand out more in color, be it white or grey or orange depending on weather and time of day. It will help make them appear thicker in density as well. The interior settings are not so commonly used, but Bleak Falls barrow would be the first dungeon you'd come across that you'd see the clouds from an interior location. The curve here adjusts Contrast, and as such can cause conflicts as each weather type has it's own specific contrast levels regardless of mods or vanilla.
The Edge intensity and clamp values will slightly alter the appearance of the outer edge of the clouds and how they appear to blend with the main body. Lower values can make them appear more like a mist accumulating into the body while higher values can make the clouds appear like a fluffy cotton ball. (Not literally)
GradientIntensityDay=1.0
GradientIntensityNight=1.0
GradientIntensityInteriorDay=1.0
GradientIntensityInteriorNight=1.0
GradientDesaturationDay=0.0
GradientDesaturationNight=0.0
GradientDesaturationInteriorDay=0.0
GradientDesaturationInteriorNight=0.0
Gradient is a term that refers in this case to the underlying sky beyond the clouds. These settings will make adjustments to the sky coloration as a whole, while the settings below will fine tune them individually based on relative position compared to the horizon. Intensity here will strengthen or weaken the color as it is, while desaturation will remove saturation. This can give your night skies a pitch black look, really making the details such as stars pop out, which is good. But again, load different weather id's and test. What you just made into eye candy can take the next weathered sky and turn it into mud.
GradientTopIntensityDay=1.0
GradientTopIntensityNight=1.0
GradientTopIntensityInteriorDay=1.0
GradientTopIntensityInteriorNight=1.0
GradientTopCurveDay=1.0
GradientTopCurveNight=1.0
GradientTopCurveInteriorDay=1.0
GradientTopCurveInteriorNight=1.0
GradientMiddleIntensityDay=1.0
GradientMiddleIntensityNight=1.0
GradientMiddleIntensityInteriorDay=1.0
GradientMiddleIntensityInteriorNight=1.0
GradientMiddleCurveDay=1.0
GradientMiddleCurveNight=1.0
GradientMiddleCurveInteriorDay=1.0
GradientMiddleCurveInteriorNight=1.0
GradientHorizonIntensityDay=1.0
GradientHorizonIntensityNight=1.0
GradientHorizonIntensityInteriorDay=1.0
GradientHorizonIntensityInteriorNight=1.0
GradientHorizonCurveDay=1.0
GradientHorizonCurveNight=1.0
GradientHorizonCurveInteriorDay=1.0
GradientHorizonCurveInteriorNight=1.0
This is where the separation begins. Think of the Gradient sky in terms of 3 levels stacked atop each other. Starting at the horizon, barely reaching to the distant mountain tops before the middle level comes in. This second level goes up to the point where you'd nearly have to be facing the camera straight up in order to notice the top level. As in the overall settings above, controls Desaturation, this is where you can further customize the look of the sky by adjusting the curve (Contrast), and adversely, all the other weathered skies. Adjusting the intensity values for the clouds and Gradient sky alone while leaving all else untouched would be the safest way to retain your sanity while experiencing the different weathers in game. For those of you that are curious, it's simple. ENB changes the post processing technique that the vanilla weathers, CoT, RCRN weathers etc. are designed around. The only way to make it work would be a patch of some sort which isn't in the works. When you see ENB's that are CoT or RCRN compatible, it's usually because they pretty much leave the sky alone, design the ENB with some atmospheric mood that adapts to the flaws, or just hopes no one notices.
SunIntensity=1.0
SunDesaturation=0.0
SunCoronaIntensity=1.0
SunCoronaCurve=1.0
SunCoronaDesaturation=0.0
These can truly make your game shine, quite literally. Between these values, you can make the sun appear as large or as small as you want, make the corona (inner circle) more a red hue while the outer part is more yellow or even bring the overall more of a fiery white.
The in-game impact is made even more incredible if paired with a proper sun retexture, such as Matso's Immersive Sun mod. That is why many ENB presets usually come with a new sun texture. These settings along with sun rays can completely change the day time sky for the better.
Note: The Desaturation values will have their largest impact on Sunrise/Set events. I'd recommend adjusting these values during those times only.
MoonIntensity=1.0
MoonCurve=1.0
MoonDesaturation=0.0
Same as above only for the moons. You can make them more vivid and appear more detailed with intensity, while desaturation can turn the moons from vibrant red to dull grey depending on your textures. The curve here controls contrast, which can help bring out the minute details of the texture if you have a decent resolution.
OBJECT/VEGETATION:
SubSurfaceScatteringMultiplierDay=1.0
SubSurfaceScatteringMultiplierNight=1.0
SubSurfaceScatteringMultiplierInteriorDay=1.0
SubSurfaceScatteringMultiplierInteriorNight=1.0
SubSurfaceScatteringPowerDay=1.0
SubSurfaceScatteringPowerNight=1.0
SubSurfaceScatteringPowerInteriorDay=1.0
SubSurfaceScatteringPowerInteriorNight=1.0
Although these settings are separated in their controlled values, they basically work the same, only on objects and vegetation respectively, so I've grouped them. This can adjust the contrast of both ingredient plants and bodies. It will create a slight glow and/or blur to skin and vegetation textures while darkening shadows. To me the highlighting on the plants are too much, so I don't use either of these really. Feel free to play around and see if you like it.
Note: Regarding Object SSS: "Makes frost trolls, ice/snow, trees and such glow at night when set too high. Also on skin, I get a pixely aliased contour on faces sometimes which high SS(AO) makes even worse. Exists in vanilla game too, so bug in Skyrim." - Boris Vorontsov
"Setting this higher makes people go redder, lower = whiter and brighter." - Boris Vorontsov
Note 2: This quote is an excerpt from the guide written by --JawZ-- using ENB Version .103 and Vegetation SSS hadn't been implemented yet.. My guide is updated to Version .166, so you're results may vary. Although Lifeshield has confirmed the bug with face textures is still present.
LIGHT SPRITE:
IntensityDay=1.0
IntensityNight=1.0
CurveDay=1.0
CurveNight=1.0
Light Sprite is a camera effect that creates a small reflective orb around point lights. Increase the intensity to see exactly what I mean, adjusting the curve here will change the color a bit. This setting with point lighting and fire can really set the dynamic for your fire effects in game, and not just torches and pits but your spells too. Although Light Sprite isn't as dramatic on fire spells that I've seen, but they are there.
WINDOW LIGHT:
IntensityDay=1.0
IntensityNight=1.0
CurveDay=1.0
CurveNight=1.0
Just as it says, this is how you adjust the look of your windows, inside and out, day and night. Increasing intensity makes it look stronger and inversely while Curve will adjust the contrast with a small range between white and yellow depending on the window. Although the range here isn't as great for curve, it can look great in some spots and odd in others.
VOLUMETRIC FOG:
IntensityDay=1.0
IntensityNight=1.0
CurveDay=1.0
CurveNight=1.0
LightingInfluenceDay=1.0
LightingInfluenceNight=1.0
LightingInfluenceInteriorDay=1.0
LightingInfluenceInteriorNight=1.0
Intensity here will adjust the thickness of the fog, while lighting influence works to saturate/desaturate it. Both of these values will determine the strength of the curve effect as it adjusts contrast. I'd recommend leaving the curve till last, but you will still likely end up playing between curve and influence to balance. As for adjusting the values from an interior, I honestly can't think of a location that would work. The best bet for interiors is to leave it at default, or you can mirror the exterior values for day/night respectively until you find a suitable location.
FIRE:
IntensityDay=1.0
IntensityNight=1.0
CurveDay=1.0
CurveNight=1.0
These are what control your fire effects, from torches to spells. Adjust the Intensity values to strengthen or weaken the appearance, while curve values adjust the color appearance. While Light Sprite can almost be ignored depending on your preferences, these values with point lighting will really make your game stand out in dungeons or night time depending on your lighting setup. I prefer darker nights to really make campfires and torches stand out and hold their own.
PARTICLES:
IntensityDay=1.0
IntensityNight=1.0
These settings will effect your particle effects in similar fashion to volumetric fog, by making them appear thicker (swamp fog, steam) or vibrant (dust, sparks ((Not the spell) while the lighting influence will adjust the contrast where smoke or fog particles are concerned. Making the effect appear white or black, or in between. With all the very many different particle effects ranging from magic, to landscape, to firepits and dwemer ruins, etc, you are bound to run into unintended effects. So again, tweak carefully and prepare to readjust and fine tune as you go from location to location. I personally found the easiest way to tweak a nice balance all around, was to adjust the swamp fog around Morthal to my liking for exterior day/night while adjusting a combination of dungeon fog or dwemer steam/ fire smoke for interior day/night settings and making minute changes along the way for other effects. Results and techniques will obviously vary depending on personal taste.
COLOR CORRECTION:
UsePaletteTexture=true
Brightness=1.0
GammaCurve=1.0
This will enable the color palette that came with the ENB version or any custom one you have in use or disable to utilize the vanilla palette. Further adjustments to overall game brightness and Gamma Curve which works on an actual color curve, but not just a particular color channel like in the other settings, this works on the image as a whole. Small adjustments have big impacts. I'd recommend going no more than 0.1-0.2 at a time. I've never found a need to go more than 0.90-1.10 on either without regretting it later on, (Curve more than brightness).
SHADOWS:
ShadowCastersFix=true
ShadowQualityFix=true
DetailedShadowQuality=-1
UseBilateralShadowFilter=true
ShadowFilterQuality=0
ShadowBlurRange=3.0
The two Shadow Fixes here will simply fix shadows that weren't properly being cast in vanilla and the quality. I'd leave them both enabled. The Quality values here, as always, lower for quality, raise for performance, while the blur range is a secondary blur to that of what's in the Skyrim.ini. Honestly, I leave it as is, I've never noticed much of a difference altering the value of BlurRange.
The BilateralShadowFilter however can make quite a difference. This toggles what appears in game as almost a dark outline on NPC's and plants, rocks, etc. Toggle it on and off and see the difference for yourself. It's not a performance hit, however I do play some presets with this disabled and some enabled. It just depends on the atmosphere.
DEPTHOFFIELD:
FadeTime=0.1
If and when DoF is enabled and installed, this value simply adjusts the amount of time it takes for the camera to be centered on the subject before the blur effect occurs. Keeping this at higher values will prevent you from going in and out of the effect constantly, like stopping to pick ingredients, and your game will run more smoothly for it. Especially since most people use this for screenshots.
SUNRAYS
SunRaysMultiplier=0.4
This setting is where you would increase/decrease the intensity of the rays coming off your sun. This will increase the number of rays emanating from the sun as well as their relative length from the sun itself.
SKYLIGHTING:
Quality=2
FilterQuality=1
AmbientMinLevel=0.2
Changes the quality and filter of the SkyLighting effect if enabled as well as adjust the minimum Ambient light level emitted to further control the effect in tandem with the Ambient and Direct lighting settings found in ENVIRONMENT.
REFLECTION:
Quality=1
FilterQuality=2
FilterBluriness=0.1
SizeScale=0.5
Amount=1.0
Power=1.0
GlosinessMin=0.0
GlosinessMax=1.0
EnableDenoiser=true
DenoiserType=2
EnableSupersampling=false
ExteriorEnable=true
InteriorEnable=true
This is NOT going to effect the beauty of your water reflections... so get that out of your head. This is yet another lighting technique, specifically for reflecting light off of objects and especially armor when enabled, this is another performance hitter. You can adjust the quality and blur applied to the reflections as well as radius (amount) and intensity (power) applied. Glossiness Min/Max values will limit the range of "Gloss" that is applied. You have the option to enable SuperSamplingAA to the effects, as well as choose whether it's enabled only indoor, outdoor, or both. DenoiserType is the quality of denoiser, so lower values for a better quality if you enable it. Noise is a type of graphical flaw or imperfection that can occur with certain effects, such as AO, and it's similar to a Film Grain effect. I notice it especially in tree shadows, sometimes on flowing water, or especially in earlier ENB versions with SSAO enabled, when the camera is being rotated.
IMAGED BASED LIGHTING:
AdditiveAmountDay=0.1
AdditiveAmountNight=0.1
MultiplicativeAmountDay=0.0
MultiplicativeAmountNight=0.0
ReflectiveAmountDay=1.0
ReflectiveAmountNight=1.0
These settings will adjust the amount of lighting applied to static objects throughout the landscape, (noticeable on mountains especially). The values here correlate to the Multiplier values, while the Reflective values will determine how reflective the light and objects effected become as a result. Image-Based Lighting is where you can really make your water reflections shine, bringing very high detail to the images reflected in the water. Obviously, this can have a performance effect as well, so play around with it to find a balance if need be.
RAIN:
Enable=true
EnableAntialiasing=false
EnableSupersampling=true
MotionStretch=1.0
MotionTransparency=0.8
TransparencyCompensation=1.0
Enable these settings if you want to use the optional rain drops that are supplied with most ENB versions. Apply SuperSamplingAA to the raindrops as adjust the "Stretch" which does just as it says, creating a longer, slender drop while in motion. The Transparency values will adjust the transparency level as the rain is in motion, and how much the lighting will effect it. I've never cared for the ENB rain personally, so I've never used it. Don't bother enabling this unless you're playing during a storm in game, as it changes the look pretty drastically in my opinion. Toggle the effect in the GUI to see which you prefer, then play with the settings.
This concludes the ENBseries.ini tweaks. From here we will go into more information about where to find and how to add different overlay effects such as DoF, Film Grain and Vignettes. However, I'll be focused on getting screenshots together and uploaded before I continue on to this segment.
ChaotiKPranXter
PROXY SETTINGS:
GLOBAL:
UseEffect=true
FIX:
FixGameBugs=true
FixTintGamma=false
RemoveBlur=true
GAME:
SpeedHack=false
- Boris Vorontsov
MULTIHEAD:
VideoAdapterIndex=0
LIMITER:
FPSLimit=30.0
INPUT:
//back
KeyReadConfig=8
//shift
KeyCombination=16
//f12
KeyUseEffect=123
//home
KeyFPSLimit=36
//num / 106
KeyShowFPS=106
//insert
KeyScreenshot=45
ENGINE:
MaxAnisotropy=16
EFFECT:
EnableBloom=true
EnableSunRays=true
ANTIALIASING:
EnableEdgeAA=true
BLOOM:
Quality=0
AmountDay=0.25
AmountNight=0.25
ContrastDay=1.0
ContrastNight=1.0
CAMERAFX:
SSAO/SSIL:
SamplingQuality=2
SamplingPrecision=2
SamplingRange=0.3
FadeFogRangeDay=2.0
SizeScale=0.35
FilterQuality=1
FilterType=4
AOAmount=1.5
ILAmount=4.0
AOMixingType=2
AOIntensity=1.0
AOType=1
NIGHT/DAY:
ADAPTATION:
AdaptationTime=0.4
AdaptationMin=0.1
AdaptationMax=100.0
ENVIRONMENT:
ColorPowDay=1.0
ColorPowNight=1.0
SKY:
Enable=true
StarsIntensity=1.0
StarsCurve=1.0
CloudsCurveDay=1.0
CloudsEdgeClamp=0.5
SunIntensity=1.0
SunDesaturation=0.0
SunCoronaCurve=1.0
MoonIntensity=1.0
MoonCurve=1.0
OBJECT/VEGETATION:
LIGHT SPRITE:
IntensityDay=1.0
IntensityNight=1.0
CurveDay=1.0
CurveNight=1.0
WINDOW LIGHT:
IntensityDay=1.0
IntensityNight=1.0
CurveDay=1.0
CurveNight=1.0
VOLUMETRIC FOG:
IntensityDay=1.0
IntensityNight=1.0
CurveDay=1.0
CurveNight=1.0
FIRE:
IntensityDay=1.0
IntensityNight=1.0
CurveDay=1.0
CurveNight=1.0
PARTICLES:
IntensityDay=1.0
IntensityNight=1.0
COLOR CORRECTION:
Brightness=1.0
GammaCurve=1.0
SHADOWS:
ShadowBlurRange=3.0
DEPTHOFFIELD:
FadeTime=0.1
SUNRAYS
SKYLIGHTING:
Quality=2
FilterQuality=1
AmbientMinLevel=0.2
REFLECTION:
Quality=1
FilterQuality=2
FilterBluriness=0.1
SizeScale=0.5
Amount=1.0
Power=1.0
GlosinessMin=0.0
GlosinessMax=1.0
EnableDenoiser=true
DenoiserType=2
ExteriorEnable=true
InteriorEnable=true
RAIN:
Enable=true
MotionStretch=1.0
ChaotiKPranXter
(WIP)
CREDITS
Aiyen - Contributor
