1 - 11 of 11 Posts
so i came home from work
about an hour ago and turned my computer on...
and i herd a gurgling noise i went oh no u don't bloop off you go open it up no sign of water turn it back on see lil drops coming off a 45 degree angle i have installed back off it went, dried it up, tighten it up, seems to be holding now
why would it leak all of sudden i had this thing running full bore for 24 hours its got me wondering
Super Moderator
Huh?
Can't understand your post at all man. Can we get some proper spelling and at least SOME punctuation in there?
A 45 degree turn was leaking. He tightened it. Stopped leaking. Was working fine for twenty four hours. He is asking why it would start leaking.
Im going to say the heat in the water had a small effect on the gaskets or something.
Super Moderator
Heat or pressure, depending on how loose the fitting was to begin with. More than likely heat related though.
Discussion Starter #6
yes...im going to refrain from posting on here right after work my brain is still fried from stocking shelf's and playing with cans all night
it was coming form the hose i just tightened down the clamp i have the 2 45's almost right next to each other only like a 3 inch tube connects them i should have went with a 90 degree ones but idk what i was thinking
Sometimes over-clamping can cause leaks as well. Too tight with a screw clamp could cause a biased binding of the tubing around the fitting.
Discussion Starter #10
Originally Posted by Angrybutcher View Post
Out of curiosity, what 45's are you using?
enzotech 45 rotatory
Interesting. One of my Enzotech 45s leaked in my BOINC rig. Seemed to be the rotary portion that leaked, until I retightened to adjust the tube position.
1 - 11 of 11 Posts
