1 - 20 of 75 Posts
Discussion starter · #1 ·
SOURCE
The Source Leads to another Forums in Guru3d.
I know most of you will wait for nvidia to release them, But hey here you go.
I think someone report BFBC2 GPU Usage Fix.
***2nd update***
Downlaod Link Updated
Originally Posted by Limes View Post
Heres a link pulled from page 2, since the first link wasn't working or is down.
http://www.megaupload.com/?d=WP5P9AHX
***3rd Update***
BFBC2 Update Source
***4th Update***
Heres a test someone did : 260.52 vs 258.96 Drivers
260.52 VS 258.96 Review(USER TEST)
Discussion starter · #3 ·
Thank you , ill go ahead and add that in OP +rep
Do they fix the BC2 error?
Discussion starter · #7 ·
Originally Posted by Rage19420 View Post
I did see a fairly significant increase in FPS as well, however there still is the annoying lag/stutter in loading a new map.
For how long like 10-20sec ? Or Just stays like that ?
Discussion starter · #12 ·
Originally Posted by SecrtAgentMan View Post
How well are they working?
From what i heard yes. Except some user are having some Opencl issues.
From what I read, people reported better BC2 and Mafia2 performance. As in no more fps drops or stuttering, rather than actual fps increases. I might try this one out when I'm home and see how it goes.
Stuttering worse in Bc2 with these drivers here!!!
i got +9 fps increase in Crysis. And overall IQ is better + sharper. Will post updates.
Update 2:- Games are lot smoother and no jerks here.no dpc problems.
Update 3:- Mafia 2 is butter smooth with Apex max.
Update 4:- Crysis Warhead almost same fps but very much smooth.
Originally Posted by Dillmiester View Post
Just installed these and had artifacts and hard freezing. System restored to the WHQL drivers and everythings fine.
http://forums.guru3d.com/showpost.ph...5&postcount=88
Based on that ^ post, your card might be why.
Also, it looks like they threw out G80 and older support for now so I made a modded inf for it. Get it here if you need it.
Lets see if I get an increase in BC2 since I only get like 55-65% load with spikes to 75% and the fps stays at ~45-55
1 - 20 of 75 Posts
