Source
Have note seen a realtek driver posted since 2.14 so here is a new one with supposed Windows 7 support.
Download
Realtek HD Audio 2.18 Driver OS Support: Windows XP/Vista 32 and 64-bit Software Description Download Realtek HD Audio 2.18 Driver for Windows XP and Vista The latest download of Realtek's HD audio driver version available for Windows XP and Vista -it supposedly runs under Windows 7 too. The HD audio driver version for Realtek chips is available for download on our server. This download offers both the Windows XP and Vista binaries, the files contain drivers for the 32 Bit and 64 Bit versions. All Realtek HD audio chips, which are common on many motherboards and in notebooks, are supported. The sound specialist still offers the Beta version 0.1 of the 3D Sound Back Utility which preserves or reactivates 3D sound effects such as Surround, reverb and stereoscopic effects of older games under Windows Vista. Since it is a beta version, the use is used at one's own risk only. You should backup your important files before using the software. Here is an extract from the change log . Unfortunately improvements of performance are rare for new audio drivers. An uninstall problem in Windows 7 has now been fixed. Realtek HD Audio Driver support all of Realtek HD Audio Codec in Vista/WinXP/Win2000/Win2003 . History - Driver Package R2.18 Realtek HD Audio Driver support all of Realtek HD Audio Codec in Vista/WinXP/Win2000/Win2003 . 1. Vista WHQL Supporting: ALC882, ALC883, ALC885, ALC888, ALC889, ALC861VD, ALC660, ALC662, ALC663, ALC665, ALC260, ALC262,ALC267, ALC268, ALC269, ALC272, ALC273, ALC887 2. Windows 2000/XP WHQL Supporting: ALC880, ALC882, ALC883, ALC885, ALC888, ALC889, ALC861VC, ALC861VD, ALC660, ALC662, ALC663, ALC665, ALC260, ALC262, ALC267,ALC268, ALC269, ALC272, ALC273, ALC887 3. HDMI Device WHQL Support: ATI HDMI Devices 4. OS Supporting: Microsoft WindowsXP, Widnows2000, Vista, Windows7 x86/x64 5. Pack with Microsoft High Definition Audio UAAV1.0a(5013) 6. Add/Fix 1.) Driver : 1. Customizations. 2.) Package : 1. Support driver folder of Windows Server 2008 in package . 2. Disable Status Dialog when small VGA Mode enabled . 3. Fix CreativeUp folder disappear issue . |
Download
