guyz is this will work?
777 Views 20 Replies 12 Participants Last post by  NvidiAFtW
ok guyz,what do you say?2 days left before order.need to know if
is this will work nicely
Processor:Intel Core i7 940,http://www.newegg.com/Product/Produc...82E16819115201
Motherboard:EVGA 132-BL-E758-A1 LGA 1366 Intel X58 ATX Intel Motherboard ,http://www.newegg.com/Product/Produc...82E16813188039
Memory:Crucial Ballistix 6GB (3 x 2GB),http://www.newegg.com/Product/Produc...82E16820148251
Video card:295GTX:http://www.newegg.com/Product/Produc...82E16814130449 (will SLI x2)
Hardware:640Gb,http://www.newegg.com/Product/Produc...82E16822148335 (make it 2 1.2Tb)
PSU:Corsair 1000W,http://www.newegg.com/Product/Produc...82E16817139007 do i need higher W?
Case:http://www.newegg.com/Product/Produc...82E16811133021 (do you suggest better one?)
Monitor:ASUS 24Inch http://www.newegg.com/Product/Produc...82E16824236033
CD/DVD drive:http://www.newegg.com/Product/Produc...82E16827151171
Hoping for a nice replays!
1 - 20 of 21 Posts
sorry man, my comment was not appropriate. I see that you have it on order now
It will sure be a nice computer!
i like ur rig
change one thing:
get the i7 920. why spend $300 more for the 940 when its the same CPU with different speed?
get the 920 with a good cooler and OC it to 3.0ghz+ and save money!
Looks great, are you planning raid with the two HDDs? No you do NOT need more than 1000w and probably could get by with less, even a 850, but nobody will fault you with 1000.
Good Luck!
EDIT: agreed on the 920 vs 940 save your money
Originally Posted by Nautilus View Post
what a grammar...
I would rather talk to someone with poor grammar than someone who's rude. Especially to a new member.
i second this. atleast some people can speak more than one language. i know my spanish i learned over the last 3 years is probably no better than his english, if not worse! lol
Heyah, NvidiATW
My apologies for the lack of courtesy from some of our members, I am sure (or I hope) that these people do not mean it in a genuinely malicious manner... they are merely going through the motions.
That aside, your build looks quite nice. Fwiw, here are a couple of things that you might want to consider:
  • Replace the 940 with a 920. You could readily regain the lost CPU speed through overclocking
  • A larger monitor: The money saved from the CPU should help fund that change.
...just my
Your PSU should be fine for the System that you have listed.
Good luck, and when the time comes, enjoy your smokin' i7 system.
lol, a bigger monitor?
24" would be plenty for me, im just fine with my 22"
glad to see people agree with my 920 swap.
Hey guyz!let me say this first before i go i7 920.
(i have been gathering money since duel cores came out and i still have them)and im sure i will have enough budgest for 26 monitor ,not a problem
you guyz say go for i7 920,let me tell you this,i got enough budget for this i can get:
Core 2 Quad Extreme
i7 920
i7 940
i7 965 and the Extreme edition.
are you sure that i shell stay on 920?
(i dont realy understanding with processor much tho)
Hope for nice replays and thanks all!
If you are sure that you can afford that kind of setup than go for the i7 965! This way you are future proof!
Everything else seems fine except I recommend getting the Cooler Master Cosmos S for a case...
Cheers bro!
First thread and he gets a Syr reply!
That rig is looking nice but you might be better with just one 295GTX for now and save your money for the next big card. The 295GTX will handle any game as of now and 2 just might be overkill. If you've got the cash though; go for it!
dont worry for the next big cards,im sure i wll be able to get them
my only question is wihch of these processor i7 965 or the EXtreme edition?
and you can you guyz say a excllent cooler?
Hope for nice replays!
The i7 965 is the extreme edition bro!
As for cooler see Thermalright Ultra-120 Extreme RT 1366 CPU Cooler
OK then!order is done!
Thank you guyz all and thank you OCN
my new PC will be shipped in 1 week Gz for me
(i hope i will stick this for couple years)
i'd...
get an i7 920 instead of a 940
get 3 GTX 285 SSC's instead of a 295 - tri SLI scales better
i personally have a love for the antec 1200. get whichever case makes you happy. you might want to chuck in a copy of Vista 64-bit just to be certain if you don't have one, or you could try windows 7 beta
it looks like it will work to me.
1 - 20 of 21 Posts
