1 - 20 of 22 Posts
You guys just have to see the size of this massive heatpipe heatsink that was reviewed by the crew at Driver Heaven today. The cooler is called the Cool Idol from Titan and the damn thing is almost as big as the motherboard it is sitting on.
After installing the Cool Idol on our P5K-VM motherboard, we came to realize just how large this cooler is. The body of the cooler floats above the CPU area, covers the entire Northbridge chip and PWM and should also cover the DIMM slots on many motherboards.
Source
That looks reallly reallllly realllly good for htpcs.
Originally Posted by Spart
The angle and the fact it's a micro atx board make it look alot bigger than it really is.
thank you for saying that, i thought it was an atx board
Originally Posted by Torched-Geek
I don't think that the testing was conducted in a completely fair way though, a Xigmatek S1283 was beaten by the stock cooler on idle.
Yeah. I don't think they applied the TIM to the HDT-S1283 the correct way.
Originally Posted by SugarySnack
How come almost nothing comes close to the TRUE still? It has been on top for far too long (A Lapped True at least. Or that craz Copper True
Because most of these heatsinks cost a good $40-50 less than a TRUE.
The TRUE is only around for people who want to get the max oc out of quad cores. With any dual core processor an HDT-S1283 performs just as good as a TRUE.
Originally Posted by sLowEnd View Post
I think you mean $20-30 less
A TRUE is $57
I'm sure most coolers aren't $7-17
True doesn't come with a fan, so if you really want to compare it, most heatsinks STOMP the true
tim?
1 - 20 of 22 Posts
