1 - 6 of 6 Posts
Has anyone had this keylogger and sucessfully removed it.I use avg and ad-aware se/spybot sd all updated daily.Ad-aware always finds it and removes it but then finds it again in a day or so.I have tried safe mode scan and removing but this fails to get rid of it.It is a very nasty key logger that gets passwords,credit car numbers e.t.c; I reall need help with this people,please help!!!
Is there something that keeps reinstalling it, perhaps? Do you have a hardware firewall with all the incoming ports closed?
Scan in Safe Mode" with the Restore feature disabled! <br />
Than remove the backup files for the restore feeature, they are probably hiding in there.
Automatic [email protected]@@k removal: <br />
<img src="http://www.2-spyware.com/pics/download.gif" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /> <a href="http://javascript<b></b>:DownloadRedirect('http://www.pctools.com/downloads/afl_2-spyware/sdsetup.exe','http://www.2-spyware.com/download-doctor.php')" target="_blank">download removal software</a><br />
<br />
<b>[email protected]@@k manual removal:</b><br />
<u>Kill processes</u>:<br />
temp#01.exe, temp$01.exe, temp#01.exe, temp$01.exe<br />
<a href="http://www.2-spyware.com/articles/security/57.html" target="_blank">Help: how to kill malicious processes</a><br />
<br />
<u>Unregister DLLs:</u><br />
[email protected]@@k.dll, [email protected]@@k.dll<br />
<a href="http://www.2-spyware.com/articles/security/54.html" target="_blank">Help: how to unregister malicious DLLs</a><br />
<br />
<u>Delete files:</u><br />
[email protected]@@k.dll, temp#01.exe, temp$01.exe, [email protected]@@k.dll, \emp#01.exe, temp$01.exe<br />
<a href="http://www.2-spyware.com/articles/security/47.html" target="_blank">Help: how to remove harmful files</a><br />
<br />
<u>Misc:</u><br />
Installs when opening Misc. Game "trainers". See "User Comments"<br />
<br />
<b>Other programs to remove [email protected]@@k:</b><br />
• X-Cleaner - <a href="http://www.2-spyware.com/review-x-cleaner.html" target="_blank">Review</a> - <a href="http://www.2-spyware.com/goout.php?id=3" target="_blank">Download</a><br />
• Spy Sweeper - <a href="http://www.2-spyware.com/review-spy-sweeper.html" target="_blank">Review</a> - <a href="http://www.2-spyware.com/articles/tutorials/75.html" target="_blank">Tutorial</a> - <a href="http://www.2-spyware.com/goout.php?id=6" target="_blank">Download</a>
Discussion Starter #5
I think some program I am using may be re-installing it but don't know which one.Don't have hardware firewall only sp2 firewall.Don't know how to check which ports are open or closed either.
Discussion Starter #6
Ok Trippen out you may have it, I often use a trainer when playing C&C zero hour.I will have to get rid of the trainer program then will do safe mode scans with restore off but how do I delete the backup file ? thanks everyone.
1 - 6 of 6 Posts
