On a H100 what is the best possible fan for a push configuration from a performance, reliability and noise standpoint? Am I correct in looking at only PWM fans ?
COUGAR CF-V12HP Vortex Hydro-Dynamic-Bearing (Fluid) 300,000 Hours 12CM Silent Cooling Fan with Pulse Width Modulation is used and many say it performs very well.
http://www.newegg.com/Product/Produc...82E16835553002
Noiseblocker NB-Multiframe M12-P 120mmx25mm Super Ultra Silent PWM Fan - 1000-2000 RPM is another choice but not any info on performance with a H100. I read a post that these make a clicking sound when at 1000 rpm , anyone know for sure?
http://www.performance-pcs.com/catal...ac33c1715adf37
It appears the above two are top choices based on performance , noise and reliability. There are delta fans that will outperform but have terrible noise problems, but I do wonder how a delta would perform when controlled by PWM.
Interested to hear opinions on the best of the best , at this point lets leave value/cost out of the deliberations.
