Ok, I have a question. I have my radiator mounted inside the case and the fans on top blowing into the case. I've read that this is best because the radiator isn't as hot as you would think and it's actually being cooled by the fans while blowing cool air into the case. Is this true? Is there a better setup? If wanted to do push/pull I know I'd need 2 more fans. What fans do people recommend that aren't terribly expensive? Thanks!
