1 - 3 of 3 Posts
Hello,
I just bought Corsair H110, but stupid me checked just whether my case has 2 properly placed 140mm mounts and not whether there is also place for radiator (Fractal Design Define R3). So now I have to upgrade also my case. Which case would you recommend?
  • ATX (my mb: Z77A-GD80 thunderbolt)
  • Midi-tower
  • Without side window if possible
  • USB3 is a plus
  • Price doesn't really matter
  • If it would have minimalistic design as Fractal Design Define has, that would be very shiny
I checked Fractal Design R4, but I'm afraid there won't be enough room for the radiator. It is bigger than R3, however my motherboard is kind of ******ed and the radiator can't cover it even a little because of this: https://dl.dropbox.com/u/1799304/IMG_0198.jpg
Thank you
1 - 3 of 3 Posts
