I have had this same H50 for about 4 years now. No leaks, no too load, running the pump at full the entire time I have had it. Originally used whit a Q6600 when they first came out. Now I have a 2500k @ 4.6 Ghz with 1.35-1.37v. CPUID says it jumps around.
My idle temps are between 20C and 38 for all the individual cores at once. Is that weird? This is with HWmonitor. My gaming temps around 50-60C but when I stress it with intel burn test it goes up to 79-81 before it fails. I just replaced the TIM thinking that would help and it has.
My H50 is in a push-pull config as an exhaust out of the rear of my 810 Switch. I don't know or talk to anyone else that has an H50, so my question is are these normal temps? The fans are the stock fan and a nzxt fan from my old zero case so each are around 50-60 cfm. I do feel the air coming out but its always cold even when stressing it. Would higher cfm fans help? The air comes out cold anyways.
