I just bought a h60 because it was on sale. I also bought a Raven RV03 case. I found 2 old Gelid Solution Silent 12 fans. Was wondering if I could use that as a push/pull on the H60 radiator. Or would the stock fan be better?
It depends, do the Gelid Solution Silent 12 fans have high static pressure? If they do, then throw them on the radiator, if not, stick with stock. I currently run two Gentle Typhoons AP-15's on my H60 and love it for the static pressure.
Suggest you use the corsiar stock fan as push and the other as pull.
Theory is, using the stronger fan as the push and the weaker fan as pull, That way you maximise your cooling and wont permaturely burn out your pull fan.
