hi
So when i first installed the watercooler, the software corsairlink2 detected the two fans and the temp and the pump speed. few days later it doesn't show up anymore in the corsairlink2. i am not sure what i did to cause this. i remember i did some overclocked and and load some saved bios setting in the bios. i have a msi p67a gd65. i connected the watercooler usb to the bottom red 'JUSB' header it worked and detected when i installed it my first time. but now it show up as an unknown device in device manager and code 43, mean something wrong with the device and it got disabled.
i wonder if there is some setting in the bios of the mobo that causing this?
is the mini usb connected to the waterblock is an universal mini usb that i can purchase at radioshack? i want to test it with a mini usb on one end and regular usb connector to connect to the back of the motherboard.
please help.. thanks..
the temperature look fine and the last time i set the fans speed to quiet mode, luckily it doesn't make so much noise as balanced mode ..
