I'm planning a ITX build in a Corsair 250D. My plan is to put a H100i on my CPU, and I was thinking about putting a H80 on my GPU - I believe the case is short enough that I should be able to mount the radiator on the front of the case. My question primarily lies in this: I'll have two available USB 2.0 headers on the motherboard - 1 will be occupied by the CPU cooler - can I put the H80 on the second USB 2.0 header and control the H80 on the GPU with the software? Can their software handle two of their coolers at the same time, and, how does it read temps? Can I read them from the GPU?
Thanks!
Thanks!
