Your pump is not sitting flush to the CPU. You are going to need to re-mount the pump and add washers to the backplate. Pick up 8: #8 Nylon washers and put them between the backplate and the board. We put 2 washers per stand off to get the pump flush to the CPU. Your temps will drop drastically after they are added.
