1 - 20 of 29 Posts
JVC HA-RX 700 30$ new 20-25$ Used
Brand - JVC
Type - Over the Ear
Model - HA-RX700
Frequency Response - 8Hz-25KHz
Input Impedance - 48 ohms
Sensitivity - 105dB/1mW
Connector - 3.5mm/ 6.3mm
Ear Coupling - Circumaural
Cord Length - 11.48 feet
Weight - 11.64 oz.
6.3mm plug adapter (Gold plated plug)
Pro's
Comfortable once you get used to
Closed headphones, isolate noise very well
Decent mids/highs/good bass but it doesn't excel at anything(good soundstage too)
Benefit somewhat when amped even by my FiiO E5.
CHEAP
Easily modded to sound better(modding tames/tightens bass)
People make fun of you in public
Doesn't leak sound in or out
Cons
bass is in a weird area, to me it sounds like too much and then not enough which is weird.
Doesn't excel at one thing, it's a good all arounder
big
Soundstage - 7/10
Bass 7/10 and 8/10 modded
Everything else is a 7-8/10
Amp'd i'd say give a .5 increase to everything.
Durability 9.5/10 very durable cans
Cable Durability 9/10
Earpads 8/10
Comfortable 8/10
Overall 7.5 and 8.0 amp'd
Modding the RX700
There's 3 mods i know of.
The felt dampening mod/foam mod on this link
http://www.head-fi.org/forum/thread/435809/jvc-ha-rx700-mods
and the felt mod
http://www.head-fi.org/forum/thread/381303/jvc-ha-rx900-modifications-a-picture-tutorial-56k-forget-about-it
(works on 700s to ofc)
The dampening mod i feel is useless
The foam mod makes the soundstage much better
The felt mod opens up the detail and tames the bass
ATH-AD700 Audio Technica's 100$ New 80$ Used
Type: Open-air Dynamic
Driver Diameter: 53 mm
Magnet: Neodymium
Voice Coil: Copper-clad aluminum wire
Frequency Response: 5 - 30,000 Hz
Maximum Input Power: 500 mW
Sensitivity: 98 dB/mW at 1 kHz
Impedance: 32 ohms
Weight: 280 g
Cable: 3.0 m (Single/Hybrid-PCOCC)
Connector: 1/8" (3.5 mm) mini stereo, gold-plated
Accessory Included: Detachable 1/4" (6.3 mm) adapter
Pro's
The most comfortable headphone's i've ever worn
Audio Technica replaces earpads/wings for free even if out of warranty period
Amazing mids
One of the best headphones for FPS Gaming
AMAZING CLARITY
Huge amazing soundstage
Very fun, fast headphones.
Even though there 32ohm, they slightly benefit from an amp. but not that much
You look like a dork in public
Ladies like dorks^
Cons
Purple
bass is anemic but it's there and slightly felt, you can 100% hear the bass though.
Some people dislike the earpads
High's can be grainy but you only notice it if you listen for it
Big
Leak alot of sound out/in
Soundstage 10/10
Bass 5/10 7/10 eq'd and amp'd
Mids 10/10
Highs 8/10
Durability 10/10
Cable durability 10/10
Earpads 10/10 for me. Don't even feel the headphones
Comfortable 10/10
Overall 8.0 and 8.5 amp'd
Even though the AD-700 aren't bass headphones, i can't seem to stop using them for dubstep even instead of my rx 700's
All in all 2 very good entry level cans
Frequency Response
graphCompare.php?graphType=0&graphID[]=2661
AD-700 MODS
Boom mic mod - http://www.head-fi.org/forum/thread/490831/my-elegant-ad700-boom-mic-mod
Fit and comfort mod/Real circumaural headphone - http://www.head-fi.org/forum/thread/505053/audio-technica-ath-ad700-fit-and-comfort-mod
Xonar DX 40$(Got it USED on ebay/expect 60$ used/80$ new usually)
Device Class: High-Definition Audio Device
Device Interface: PCI-Express 1x
Audio Processor: ASUS AV100 (C-Media CMI8788 OxygenHD)
Analog Outputs: 3.5mm mini-jack x4
Analog Input: 3.5mm mini-jack x1 (shared by Mic In and Line In)
Front-Panel Header: Intel HD Audio and AC'97 compliant
Other Line Level Analog Input: Aux-In (4-pin header)
Digital Input: High-Bandwidth TOSLINK optical transmitter (shared with line-in/microphone jack)
Audio Playback Sample Rate: 44.1k/48k/96k/192kHz
Audio Playback Resolution: 16-bit/24-bit
Audio Recording Sample Rate: 44.1k/48k/96k/192kHz
Audio Recording Resolution: 16-bit/24-bit
S-PDIF Digital Output: 44.1k/48k/96k/192kHz @ 16-bit/24-bit, Dolby Digital
Output SNR: 116dBa (front L/R), 112dBa (other channels)
Input SNR: 112dBa
Output THD+N: 0.00056% (-105dB) @ 1kHz (-3dB, front L/R only)
Input THD+N: 0.0004% (-108dB) @ 1kHz (-3dB, line-in)
Frequency Response: <10Hz to 48kHz (-3dB, 24-bit/96kHz format)
Analog I/O Full Scale Voltage: 2 Vrms (5.65 Vpp)
Driver Features: DirectSound 3D Gaming Extensions (DS3D GX) 2.0, VocalFX, ASIO 2.0, Dolby DSP functionality, DTS Neo:pC
Powers my brothers 250ohm Beyerdynamic headphones pretty good too
Pro's
AMAZING Soundcard for the price
One of the best entry/mid level sound card's there is
Front panel header
4PIN Aux Port
PCI E X1
Great sound quality in almost everything excepts....one...thing
Excels at music but great for gaming
Don't hear a difference between the DX and my brother's Essence ST(Which is much more expensive)
Durable
Cons
BFBC2
BFBC2
It's a tiny bit better then onboard in BFBC2 (should be okay in BF3 though!) good for literally every other game
Requires floppy 4 pin for power when the pci e x1 should easily be enough
No headphone amp like the STX but it can easily power
Regular ASUS Drivers
Overall a great mid level soundcard for people on a budget for music and gaming, IMO skip the xonar dg/ds for this card
Good drivers are the Xonar Unified Drivers located at this link
http://brainbit.wordpress.com/2010/07/19/asus-xonar-unified-drivers/
I do not take any responsibilities for any mods you do if you so choose
Headphones used at 100hrs burn in each. and they did indeed change from 0-100hrs
And that concludes mah review
+nytmare92 is my gf lmao
your reviews pretty close to what i just ordered. i went with the 900's, but the same soundcard. i got mine for $50 open box off the egg. i'm hoping to have the same luck with the card. i bookmarked this page to try out the drivers. good review! the mic mod is pretty awsome to.
Originally Posted by Nytmare92;13902743
renji1337 you suck. lol jk And the AD700s are extremely annoying to anyone around you. Especially when you are trying to sleep and renji1337 is blasting dubstep. -.-
-_-, you made an account just for that didn't you <3 lol
Originally Posted by toyz72;13902840
wanted to add..hows the software that comes with the card? if there is any?
the software it comes with is fine, but the modded drivers sound better imo
nicely done man
Hope you enjoy your system
Thanks for sharing +rep
Nice reviews. The Xonar DX seems like the perfect sound card for me....except that I play BC2
Is there any reason in particular that this card just doesn't work with BC2? and what makes you think it will work with BF3 (which I will also be getting)?
Thanks
Discussion Starter · #12 ·
Thanks
I was at E3 and i had some "spare time" to talk with some of there representatives and one of them had knowledge of the issue mostly and said that with BF3 the sound quality will be a whole new ballgame
and that it should work on any sound card great
Awesome, thanks for the info renji! I'll probably get the DX anyway considering once BF3 comes out I'll likely never play BC2 again lol.
Discussion Starter · #14 ·
yw
Discussion Starter · #17 ·
More stable/less issues with these drivers + he makes a easier/better xonar audio center so you can use 2 + it has better sound quality because he makes it less involved.
More reviews to come!
1 - 20 of 29 Posts
